4A acting like 4H, binding while turning on dry pavement
Lil Red Broncette
Explorer
MY22, 2 door, 2.3L, manual, squach, advanced 4x4
Any anybody know how 4A might suddenly act like 4H binding on dry pavement? And then fix itself after using 2H several days. I had been in 4A for months and hadn't switched modes anytime around when this started. Is this something that software sets up every time I start the car in which a software glitch puts it in the wrong mode? Is this a simple solenoid that is activated that makes 4H different than 4A?
Additional detail:
I been driving in 4A for the last several months with no issues. Last week I noticed it binding, stiff turning and moving when taking the sharp turn into the garage. I switched to 2H and got the sound of the tension unwinding. In 2H I backed out and drove without issue. I put it back into 4A and headed back to the garage. Once again I experienced the binding when taking the turn. Switching to 2H and again the tension was released. I then put it back in 4A, backed out and experienced the same binding backing out which makes sense since it was the same tight turn but in reverse after I released the tension. Once again switched to 2H to release tension.
To confirm it was the same as 4H I performed the same sort of experiment in 4H and got the same binding. So I put it in 2H and parked it overnight.
In the morning I put it back into 4A and it exhibited the same issue. I put it in 4H and went to work. After work I put it in 4A and experimented in the parking lot at work turning tightly and had the same issue.
I made an appointment with the dealer which is later this week. I continued to drive it in 2H. Yesterday I decided to see if it was still exhibiting the issue and put it in 4A. Of course it is no longer occurring.
Thatguylegit69
Zachary
2023 Bronco & 2012 Ford Raptor
[/QUOTE]
To clarify, you're saying you engaged 4H and drove to work?
