CarbonSteel
Colorado Springs
2023 Carbonized Gray
I have been working on this for a while now. Although the service manual has the torque specifications scattered throughout the document, there is not a single listing of all of them. I bought the manual a while back (custom tailored to a 2.7L Wildtrak, but I would assume it works for all 2.7L and Automatic versions) so the specs for manual transmission and clutch is not included.
Use this at your own risk as there could be oversights on my part, but I have checked the data at least twice. Hope this helps someone.
**LATEST UPDATE - 04 January 2026 - Added skid plate torque specs**
Link To Torque Specs
JerryC
Memphis
2022 Bronco
Thanks for compiling the list.
The torque for wheel stud nuts, if that is meant for lug nuts is not correct. 147 ft/lbs is too much. It should be 100 ft/lbs.
CarbonSteel
CarbonSteel
Colorado Springs
It was to pull the studs into the hub, but I changed it to prevent confusion.
Thanks.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Dang. Feel free to compile one for 2.3L/7MT too 😆 (I’m sure there’s plenty of crossover).
I appreciate the effort put into this. Thanks. 🍻
CarbonSteel
CarbonSteel
Colorado Springs
If you have the 2.3L and 7MT manual, I could do it. I bought the "official" one so that I did not have to worry about bad data.
My guess would be the engine and transmission (maybe transfer case) is all that would have to be added.
2DR22Bronco
Chad
Seattle area
04Cobra, 95Cobra, 17Explorer, 22Bronco
Thank you for the time and effort put into this.
Very Good Stuff!
swamp2
Great and useful project. Who can add some Raptor values. Let's cover all of the models and make it a sticky.
CarbonSteel
CarbonSteel
Colorado Springs
If someone has a copy of the Raptor service manual I would be happy to add them to the sheet.
The service manual that I bought was custom tailored to my VIN so I do not have anything other than 2.7L and 10R60 data.
swamp2
Did you get a pdf version and is it readable/usable/searchable? If so, from where and what did it cost? I've seen limited options for the Raptor version.
Squatch
Can you upload it as a PDF into AI to make a list?
I bet the Ford Bot could if you give them your VIN. ;):ROFLMAO:
CarbonSteel
CarbonSteel
Colorado Springs
It is PDF and is infinitely reusable. I was ripped off by Service Manual Warehouse who is selling the same janky garbage that you can find anywhere so don't waste your time and money with them.
Here is the place I bought mine and it appears they have the Raptor version (because I see the 3.0L engine as an option). They take your VIN and build it to your vehicle specs--it also includes the wiring diagrams:
https://www.factory-manuals.com/ford-bronco&28&503
CarbonSteel
CarbonSteel
Colorado Springs
Make a list of?
