Has anyone adjusted their headlights after lift/level? I just did mine. Clockwise will lower and counter clockwise will raise. I’m not sure how accurate my adjustment was but lowered it about 2”.
You should have put your high beams, just to show him didn't already have them on!I probably need to adjust mine. Have the 3" Zone off road Sasquatch kit and got flashed the other night by an oncoming car. If you're 25 feet away from a wall, what is the ideal height of the beam. I've seen 3.5 feet, but not sure if that is accurate.
It isn't a fixed value, it is based on the height of your headlight. IIRC it should be slightly lower than the center of the headlight. I'm sure there are some YouTube directions out there.I probably need to adjust mine. Have the 3" Zone off road Sasquatch kit and got flashed the other night by an oncoming car. If you're 25 feet away from a wall, what is the ideal height of the beam. I've seen 3.5 feet, but not sure if that is accurate.
Trust me, I did!You should have put your high beams, just to show him didn't already have them on!
What is IIRC?It isn't a fixed value, it is based on the height of your headlight. IIRC it should be slightly lower than the center of the headlight. I'm sure there are some YouTube directions out there.
"If I Remember Correctly" (IIRC)What is IIRC?
