Alternate Fog Pocket Solution Installed
imaginager
PDX / Oregon
2021 Bronco Black Diamond
Are the SSC2 Pros in stock? I need a pair of Amber and a pair of White - going to follow Bigmoose's lead on this - excellent aesthetic! DD has a 6-8 week delay on their site, was wondering if that impacts 4x4TruckLEDs?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
As of right now they are but we are still working through Black Friday sales
BroncoAZ
Mitch
Finally got some good night time pics. The biggest improvement is the wide throw of the light which is great for cornering.
Just headlights, low beams:
White pro fogs:
Yellow pro fogs:
That looks great! It also appears that the factory low beams are close to 6000K which the Diode Dynamics are a good match for. I have the SS3 fogs in amber on my Tacoma, they work great but are almost too bright. Maybe I need to rethink my setup.
sjax42
Boynton Beach, FL
Ram 1500 Longhorn
You could certainly do that. Our kits are not setup that way (1x SS3 & 2x SSC2 or 2x SS3 & 1x SSC2) but you could certainly buy our brackets w/harness and then 3x pairs of SSC2.
The reason is simple... WAY too many options then and it honestly gets really confusing for customers. Plus we like to fit as big of lights in there as we can.
But we also allow customers to just buy the brackets and harness and lights all "ala carte"
Complete Kits are here: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/
or
Brackets w/Harness Option: https://www.4x4truckleds.com/kr-off-road-triple-fog-light-brackets-for-2021-ford-bronco/
Diode Dynamics Lights: https://www.4x4truckleds.com/led-auxiliary-lights/diode-dynamics/
Baja Designs Lights: https://www.4x4truckleds.com/led-driving-fog-lights/baja-designs/
Morimoto 4Bangers: https://www.4x4truckleds.com/led-auxiliary-lights/morimoto/4banger-led-pods/
What are 4Bangers you say? Well now, those are some hot new lights on the market. We're taking pre-orders on those (ETA for shipping is around mid December). We know you can fit 2 of them on our brackets (we did it on a Raptor), not 100% sure if 3 will fit (we've only got 1 pair that were sent to us early).
LOVE the kit, so easy to install. Thanks.
Ford Bronco Alternate Fog Pocket Solution Installed tempImagelSOr7v
4x4TruckLEDs.com
Adam
Lindenhurst, NY
It's actually getting even easier tomorrow. We just redesigned our brackets after a few folks who installed them offered some feedback.
The new brackets are basically the same as the original KR Off-Road brackets, but we've extended them a bit more to give you more room for the lights to be spaced out a bit.
JAC
Joshua
Oregon
2018 Toyota Tundra; 2020 Acura RDX
This is exactly the set up I want.... couple questions maybe @4x4TruckLEDs.com can answer as well - Back lighting??? is it necessary or a must??
Even if Ala cart.... I want this set up but minus the amber and double up the white 1X2's- Any chance a parts list can be posted so I can order?? Not too worried about the 6-8 week delay.
Many thanks for the assist!
Bigmoose
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Back lighting is personal preference. You don't need it. If you go with SSC2 pods you could just not connect the backlights.
  • Like
Reactions: JAC
BroncoAZ
Mitch
Unfortunately the SS2 only come backlit. Right now you can get SS3 without backlightin, I’m not certain if without will be available after the backlit SS3 are introduced.
JAC
Joshua
Oregon
Thank you!! Any chance you can let me know exactly what you purchased?? I'll minus the amber and double up the whites. Much appreciated!!!
Bigmoose
Bigmoose
Jon
RI
Ford Bronco Alternate Fog Pocket Solution Installed Screenshot_20211120-193147
I added the harness as an option to the bracket
JAC
Joshua
Oregon
IF that is what you used, then perfect! I literally want to mirror your set up. you ordered from 4x4 truck led correct? I think so if I read this thread correctly.
Thank you Again!!!
Bigmoose
Bigmoose
Jon
RI
Thank you Again!!!
Yes I did.
Another thing to think about since you want to go with all white, maybe get a different pattern for one if them. Not sure the benefit of both being fogs. My single white fog is more than I need in that area. If I was going dual white I'd maybe get the driving pattern for one of them. Part#DD6403P.
JAC
Joshua
Oregon
Yes I did.
Nice! Thanks for the info! Okay one more question, what aux switches did you use?? Would 5&6 work?
Bigmoose
Bigmoose
Jon
RI
They would. They are 10A and the lights don't draw that much.
  • Like
Reactions: JAC
