Amp Harness
Cybindustries1904
Tony
Discovery bay
23 Raptor, Mach E GT
Just received confirmation that https://plugnplaykits.com/ will have a harness out in the next few days for the Bronco. This will make adding amps mutch cleaner and simpler.
Garemlin
Delaware
I'm guessing this is just a speaker level input of some sort.
Ford Bronco Amp Harness Screenshot (23)
da_jokker
Jeep Wrangler JKUR
I had posted a while ago as a response to one of those many audio build threads, saying it sure would be nice if someone made something that would plug in behind the head unit that would branch off for an amp... I'm assuming that's what this is?
Now the question will be, do they know they have to get the signal off the front kickers and not the rears?
DFNMAN
Anthony
Tampa, FL
21' 2dr, 15' M3, 07' FJ, 03' M3, 79' 928
22OBX
Hartford, AL
DFNMAN
Anthony
Tampa, FL
Do you have yours installed yet or are you waiting on it? You have the standard sound system?
Yes, I have the base system. I installed it a couple of days ago. It took longer than advertised to get, but it was worth the wait. It made running the wires for a 5 channel amplifier simple.
j_anderson
Jason
Fort Wayne, IN
www.instagram.com
Did you write up a how-to of your process and a parts list? I'd be interested in seeing that
22OBX
Hartford, AL
There is a video on you tube with steps on getting to the radio behind the dash. You have to remove about half the pieces on the dash to get to the radio…crazy. I think I’ll work on an alternative method and may post what I come up with. I don’t want to pop so many pieces off a brand new dash taking it apart and risk damage . I don’t want to end up having rattles on a brand new vehicle . The harness does look to be very nice though.
DFNMAN
Anthony
Tampa, FL
Bagziga
Iowa
2015 Focus ST
I finally got around to it. I didn't take pictures during the actual install, but feel free tp PM me if you have questions.
https://www.bronco6g.com/forum/threads/bronkowski-2-door-basesquatch.35013/
Awesome, thanks for sharing that information. The loopback harness sounds like a great way to do it. Did you have much trouble routing the cable under the trim back to where your amp is?
How are you liking the 2 way with the tweeter in the dash? I've been thinking about an Audiofrog system with the GB60 midbass (if it fits) and GB10 or GB15 tweeter. I'd like to later add the 4" mid for a 3 way active system but I'm hoping that the tweeters still sound good installed in place of the factory 4" speakers.
DFNMAN
Anthony
Tampa, FL
Running the wires is easy. The tweeters sound fine in that location. I am also thinking about running a 3-way set in the front, but my experience with 3-ways is you really need to run an active set up. So I would need another amp and most likely a DSP.
