Amp Research Powerstep - Availability Update
BroncoIA
P
Iowa
4Runner
Awesome! thank you for this. Too bad they are not available anywhere that I can find. AMP themselves say they are 20-22 weeks out.
I ordered them last week from Autoanything and they have already been delivered. Sign up for emails and they will send you a 15% off coupon code. It wont work on these but then if you call they will do 10% off.
_TJG_
_TJG_
Todd
Louisiana
2021 Bronco First Edition (4 DR)
I’m in Jackson Mississippi. We’re not far from one another.
I buy the rib eyes.
I passed through Jackson not long back, sounds like a plan to me!
_TJG_
_TJG_
Todd
Louisiana
Yep that’s where I ordered mine, got them for $1698 shipped (5% coupon used). They came in at around 4 days I believe! Everywhere else said 20-22 weeks, but Autoanything has them.
_TJG_
_TJG_
Todd
Louisiana
Some pics!
Ford Bronco Amp Research Powerstep - Availability Update C2D28B21-79A8-4C1A-9C0E-6BC4E9DE32EF
Ford Bronco Amp Research Powerstep - Availability Update 0C04847B-6396-4F17-99B3-964309DF2BFF
Ford Bronco Amp Research Powerstep - Availability Update 53D719C0-4B8E-4895-B8F9-C58BC64C0A12
straycat
St. Louis, MO
2011 Toyota Camry, 2021 Ford Bronco
Some pics!
Those look awesome, can't wait to get mine. Quick question though, I have the rocker panels installed to cover the pinch weld (not rock rails)....does it look like I'll be able to keep those on when installing these power steps? I'd hate to think I wasted a couple hundred bucks to get them and then have to take them off.
_TJG_
_TJG_
Todd
Louisiana
Thanks! I think it’ll be completely fine with the rocker covers. These don’t mount to the pinch weld so you’ll be good. And there’s enough room for them to operate so that it won’t get in the way. I’ve thought about getting the rocker covers myself and was thinking about that during the install. Only thing is you’ll have to drill two holes in them to run the wiring for the LED lighting. Which isn’t a problem anyway because you have to drill the holes through the pinch weld anyway. Or you can leave the lights off, they aren’t necessary.
straycat
St. Louis, MO
Great news, thanks. Not sure if I plan on running the lights for them yet or not. Do you have any pics of them with the lights on?
Lucky13!
jeff
Charlotte
Ford Flex
Anyone else put this on yet and what to share their opinion and some pictures?
boomboomthump
2022 Bronco
Anyone know where I can get a set of these perhaps? Haven't been having luck. A few folks mentioned AutoAnything but no dice. Tried realtruckparts.com, 4wp.com and runnbingboardwarehouse.
Unless I can find someone who happens to have them in-stock, it seems I'm in the backordered with no ETA waiting game. :(
MamaD
Holly
Newark,TX
61 IH Scout 80, 48 Ford Coupe, 2014 Ford Explorer
I had the Amp Powersteps installed today and I'm having a bit of buyers remorse. First of all they're damaged out of the box and 2nd they don't cover as much as the rock rails leaving an unsightly gap. I just can't unsee it. Since they are damaged I think I might uninstall and return. Does everyone else's look like this? I like except for this.
Ford Bronco Amp Research Powerstep - Availability Update 1000000870
kahunabob
Bob
Santa Clarita, CA
4runner
I have them on mine. I love them. I will have to compare your picture to mine and see if there is a difference.
I don't see any damage in your pic?
MamaD
Holly
Newark,TX
They don't suck in all the way on one side. See how it's slanted.
Ford Bronco Amp Research Powerstep - Availability Update 1000000865
I was expecting this coverage.
Ford Bronco Amp Research Powerstep - Availability Update 1000000873
And got this.
kahunabob
Bob
Santa Clarita, CA
4runner
And got this.
I think that is an install issue. Maybe needs some adjustments?
If that step is bent or tweaked, I would request a new one from amp research.
I installed my own and the gap is very small is the same for the length of the step. I don't think I would want the gap any smaller....in case there was some flex and it banged the bronco.
My steps look the same as the bronco a few posts up.
ldcobb2
Danny
Clovis, CA
cencalbroncos.com
2022 Ford Bronco
And got this.
Did your installer cut them too short? I’m pretty sure the running board is cut to size.
