Anyone painted theirs to match the wildtrak / first edition? Can you easily remove the letters before painting or just tape them? Any other suggestions? Assume any good gloss black paint will do.
Greetings...Anyone painted theirs to match the wildtrak / first edition? Can you easily remove the letters before painting or just tape them? Any other suggestions? Assume any good gloss black paint will do.
I did, but I had a shop do it. Not sure if they took the letters off or not, but I know they’re plastic welded on so in order to take them off you have to drill them off. Not sure about specific paint color either. Just told them I wanted it gloss black.Anyone painted theirs to match the wildtrak / first edition? Can you easily remove the letters before painting or just tape them? Any other suggestions? Assume any good gloss black paint will do.
Thanks for that info about the letters. I am going to have my local shop paint mine. I thought the letters were held in by screws.I did, but I had a shop do it. Not sure if they took the letters off or not, but I know they’re plastic welded on so in order to take them off you have to drill them off. Not sure about specific paint color either. Just told them I wanted it gloss black.
If I was a bit closer I'd take you up on the swap. I have a BL going into production next week. If you don't line up with anyone closer when you WT shows up, shoot me a PM.Greetings...
Where in NY are you?
I'm trying to line up someone to swap with when my WT shows up. Since I'm getting Carb Gray, I would really like to have the Badlands Grill. Might you be interested in the Mirror Caps as well?
It comes unpainted. (Ready for Paint)You could also buy a Wildtrak grille from Ford.
They come unpainted. Save money just painting your own or swappingYou could also buy a Wildtrak grille from Ford.
Oh wow! Not used to Ford parts. Sad that they don’t give you an option to buy original parts just like the factory.They come unpainted. Save money just painting your own or swapping
I couldn’t find a swap partner so I’m gonna have mine painted
