EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
G2 Raptor, GT350, Land Rover SERIES and DEFENDER
Looking much better now. Curious about the longevity of the clamp design though.
Great question!
The clamp brackets are 6061-T6 billet aluminum, along with the STIRRUP itself. 6061-T6 is rated at ~42,000 psi tensile strength. Two M10 stainless bolts mount (100,000 lb tensile strength each) the STIRRUP to the clamp brackets. Four M6 stainless bolts provide the clamping force for the brackets to the OEM rail. The M6 bolts are 70,000 lb tensile strength each. Billet aluminum is what's used on suspension parts for Baja 1000 Trophy Trucks, racing engine blocks and heads, and aerospace load bearing applications. The STIRRUP assembly is greatly overbuilt for what we'll be using it for. We're only going to throw mere hundreds of pounds at them.
DUSTYcazOREGON
Craig
2021 Ranger Tremor/2022 Bronco/2006 Dodge Charger
Great question!
Great product as usual!!!!!!!!!!!
Do you plan on clearcoating these to protect the powder coat/colored finish?
Thanks.....can't wait.
RoLyMa27
Rodney
SloKart, TX
21 Bronco, 22 Maverick
AR | STIRRUP®
The BRONCO community asked for it and we went to work! After reviewing what was shared from last year's SEMA Bronco, there was plenty of room for improvement, both in design and function.
Made from a sizeable chunk of 6061 billet, the STIRRUP is very beefy part and it will look right at home on an overland build, trail conquering rig, or your daily driver. It's five inches of width will give your boot or shoe a proper platform to assist you in climbing up in the saddle. The entire part is coated in RAL 9011 Graphite Black, then post machined to remove the coating from the top surface and reveal the raw billet aluminum and provide a very classy contrast. This will also give the STIRRUP years and years of rugged good looks. The more you step on the the more naturally worn the aluminum will look but it won't affect the Graphite Black coating.
The STIRRUP is mounted to your OEM rocker rail with M8 and M10 316 stainless fasteners. A single M8 bolt alone has 110,000 PSI tensile strength! The STIRRUP is definitely more solid than the rail it's mounted to. With its coating and the use of aluminum and stainless, the STIRRUP will require little maintenance and it will last the life of your Bronco.
The STIRRUP will be sold in pairs. This will also be a BRONCO6G exclusive part, at launch, and B6G members will always be eligible for the 20% discount. We're going to handle the purchasing a little differently this time....
AR | STIRRUP DROP BRACKET
Renders are below. The drop available from the standard STIRRUP is difference making 2". The drop bracket is substantially larger than the standard bracket. The STIRRUP Drop Bracket has been updated to the listing on the website as an option. For the majority of use cases the 2" drop would make a lot of sense.
The Drop Brackets retain all of the same ruggedness of the standard brackets. The exact same rail mount locations are used between the two brackets. So if for any reason you want to swap to a drop bracket down the road, it's a simple order and install deal. The Drop Brackets retain all of the same ruggedness of the standard brackets. They do hang down just that little bit more, so that's something to keep in mind if you do happen to find that trail with large rocks.
Drop Brackets are added to the website as both an option and will also be added later as a stand alone product. If you already have the STIRRUPS on order but want the Drop Brackets instead, email [email protected] with your Order Number. We'll make the note to your order on the back end so you receive the brackets you want, but you'll check out on the website for the new brackets, if it turns out that there's a substantial cost difference. There is no cost difference to change your order to the Drop Bracket.
Pricing:
Retail price for the AR | STIRRUP is $494.43
BRONCO6G members are eligible for a 20% discount, making the price per pair: $395.55
NOW TO THE FUN PART:
If you would like to pre-order your STIRRUP pair or set of four now, here's what you'll need to do.
1. Reply in this thread: SEND IT!
2. We will PM you with a one time use code for the ARCHETYPE RACING website.
3. Go to the link, also provided in the PM, to the STIRRUP, and you'll be able to check out with the BRONCO6G 20% discount.
4. Spam F5 on the tracking link, once you have it, while you're waiting for your STIRRUPS to arrive.
SEND IT!
ABNCH82
Jerry
Columbia, SC
92 Bronco
<RESERVED> AR| STIRRUP
BRONCO6G Member Pre-Sale
1. De Brus
2.mikey_photo
3.DubC
4.icd70
5.Daktari
6.Nobody
7.iamchewby
8.CptSamFalcon
9.Bronco21fan
10.JediMcMuffin
11.bytheway
12.gmac
13.ironiguana
14.aniljavali
15.604Bronco
16.Dubsilk
17.FindmeintheTailout
18.mljohnson1973
19.PNWBronco
20.tjdahl1911
21.PlayUltimate
22.Heeba
23.mortgagebruce
24.BroncoBoy22
25.michaeldc46
26.TheeBullhead
27.jlj4660
28.BroncoBuckaroo
29.Belem
30.GToddC5
31.T-Bronc
32.migsby_carmichael
33.BroncoOvrlndr
34.wanna1
35.corey07
36.JetG
37.Gumbeaux
38.KrazeeEyezKilla
39.redcatcher27
40.etmccaus86
41.Texasex
42.Liberty
43.PrevCYBRTRKrez
44.TommyBronco
45.Thehagermaniac
46.jkburg
47.bgcfman
48.gizmohd
49.Sherminator
50.661calibronco
51.SquatchHunter
52.Bdub2you
53.BdubBronco
54.littlepope
55.scotts418
56.orangemethodology
57.redone17
58.CG2Door
59.MtnRanger
60.Snow93
61.Jarret
62.antman92
63.bigkansas
64.DewyBanzai
65.DoubleADuster
66.Triceratops
67.djbearc
68.buckjr
69.HardenUp
70.Soup8508
71.onegdgal
72.BLBronco133
73.Aman
74.Lagrange 6G
75.FMC
76.nd2002
77.Bomar
78.pawhitejr
79.Gone Wild
80.ProudestMonkey
81.Road Warrior
82.jasetischer
83.BGBronco
84.one800higgins
85.amcap
86.erniecombs
87.Bronco4
88.kevinlockard
89.LSTLAF
90.BroncoSTL
91.BKrugby
92.hozer
93.Broncadonk MKG
94.jmalinov
95.BigJim90
96.305cashparadise
97.cd13
98.jdamach1
99.BroncoTodd
100.Dez Pony
101. SWADSP
102.Lilj4425
103.LowerDixie77
104.BroncoPVC
105.Chopper67
106.Tippster
107.Who is
108.Big Diamond
109.GreenMtnBronco
110.GoulaRun79
111.tjparisi
112.Perfect-Beast-2
113.bran134
114.dtrump
115.Fly2Win
116.Mr.Bojangles
117.EruptBronco
118.Tarheel_Wes
119.karguy08
120.Mmarto
121.Bensquatch
122.AmandaFE
123.rafterman
124.smheard
125.kmcran
126.shinersmike
127.JDUBS
128.Jolo86
129.Heymucko
130.Cousin626
131.Smackett330
132.22BlackDiamondGreen
133.FstFrd00
134.Jer
135.Arjineal
136.Dragline
137.TracytheMighty
138.VehiChase
139.Sikinboat
140.shotsy
141.4door4family
142.hammer_head
143.scc361
144.Kel
145.BroncoRed1967
146.roush062003
147.ChathamShark
148.Johare11
149.ARETE
150.Bunker704
151.SaveTheManuals
152.JMerTaw
Send it. I need two sets.
RTLGarage
AJ
New Braunfels, TX
2021 Bronco (I also have a 1992 XLT)
AR | STIRRUP®
Pricing:
Send it!
Jmax
Plymouth
Explorer
AR | STIRRUP®
Pricing:
I have a 4 door, is this for 4 or 2? If 2, is it possible to get a larger discount?
EIGHTLUG
EIGHTLUG
Curtis
Silverdale, WA
They are sold in pairs. When you checkout on the website with the Bronco6G.com coupon code applied, it's a pretty chunky discount!
Jmax
Plymouth
Explorer
Are there any pics with these actually on a bronco? Or are they not a yet?
Jmax
Plymouth
Explorer
AR | STIRRUP®
Pricing:
SEND IT
Kingexporter
Danny
Parkland, FL
Bronco First Edition
AR | STIRRUP®
Pricing:
SEND IT!!!
