ARB/Ford performance single compressor kit test on Sasquatch with 4 tire hose setup
illverado
Cory
700whp stick shift 2000 silverado 23 basesquatch 2dr 7mt
So I bought the ford performance arb compressor box deal off of ford accessories website using my FordPass points and a discount applied the day after they went live with points on the website without going to a dealer. It’s a little tricky staying logged in and redeeming points and using a coupon code but it works if you click back to cart and keep messing around back and forth clicking different things. So anyways here it is! I couldn’t find any relevant reviews so I made a quick to the point video. I did mess up but not having the engine running until about 9 minutes in, and boy when I started it the RPM of the compressor started SCREAMING- just about doubled and sounded like it was gonna explode until it slowed down some lmao. So my guess is it could definitely get all 4 aired up from 15psi to 39PSI in about 10 minutes flat. Great free accessory, thanks ford!
Kcmojoe76
Lees summit
Nothing
What coupon code did you use?
In the end, how many points did you have to spend?
I was hoping to use my collection of points to put towards a hard top, but that does not look like it will ever be an option.
I am looking at the compressor as well. I would be 100% in on purchasing it, if it was the one you could mount in the engine compartment. For now, I am debating it based on cost. But a coupon code might help me pull the trigger!.
I just ordered the ditch lights (mirror mounted). I hope I didnt miss an opportunity to save with a coupon code there!
emulous74
Seth
Austin, TX (Pflugerville)
'19 ZR2 Bison D , '23 Bronco 2DR, MT
Where in Texas are you? I have the dual with Air tank ARB version, it would be great to do a compare.
Ford Bronco ARB/Ford performance single compressor kit test on Sasquatch with 4 tire hose setup IMG_0853-XL
emulous74
Seth
Right now GET15 will give you 15% off up to $1000.00 of purchase and HELM20 will get you 20% off up to a $1000.00 purchase.
illverado
illverado
Cory
It was the code on the main page and it was like 37,000 points but had to pay tax and shipping still I believe. You can take it out of the box and mount it anywhere
Ksjrb03
Tx
F250
Code VIN20 worked for me the other day 20% off and used points very easily.
Kcmojoe76
Lees summit
Nothing
Thanks for the update guys. I actually was at my dealership the other day and ordered through them. I just called them and they said bring my coupon up and they will just apply it there. Fingers crossed!
bradcd
Brad
Indiana
Saab 9-3
I just ordered this Ford portable kit today! Glad to hear it works and quickly too. It's all the same internals as the ARB CKMP12 kit so the actual compressor inside is the CKMA12. That compressor is $338 alone but I picked up the Ford kit for $317 through Levittown Ford's website. Seemed like an excellent deal.
honorableh
2022 Ford Bronco
Mounting the single compressor is a bit different than buying one not in the case I'll warn yall.
It seems there is a different connecting plate for the box than would otherwise come attached to the compressor.
You can adapt the plates sold and replace the rivets with screws to secure it to the available mount. This is what i did. I do like using the box now as a carrying case for some straps and tubes though afterwards
