ARB Twin Compressor fan not turning
F-Spot
SoCal
Tesla, FJ
Finally got around to installing the ARB Twin Compressor in my engine bay. Got everything wired up, started the vehicle, and turned on the isolator switch...compressor turned on, but the fan doesn't turn. I can see the fan wanting to turn, but it never does. Bad fan? Wiring problem? Something else?
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Give @ARB a call and talk with the tech dept. They are pretty good to deal with.
ARB USA: 866-293-9078
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
I'd reach out to the vendor you got it from for assistance
F-Spot
F-Spot
SoCal
Tesla, FJ
Removed the shroud to check the wire connections on the compressor and noticed this pair of wires (circled in red) were bent towards the fan and was blocking the fan from spinning. I tucked the wired up and over the bigger wire loom and all is good now. Whew!
Ford Bronco ARB Twin Compressor fan not turning 303993EE-33D5-4CB2-B893-2DF05A86C458
