I used forscan today to get my windows to auto close. For those not familiar if you press and hold unlock the windows open all the way. However, the close feature with the lock button doesn't work by default.
In order for this to work I had to edit the BCM (non as-built). There are entries for auto window open and close. I just made the close options match the open ones.
I also had to edit the door modules, DDM and PDM, to enable auto close as well. Again I used the non as-built so I wasn't messing with hex values.
I noticed on my 4 door when closing the first time you hold lock to close the fronts only go up an inch and the backs close all the way. A second cycle and the fronts close all the way.
