AUX WIRING: DRLs (always on)
F1NDx
Detroit, MI
Couldn't find anything regarding this except on Jeep Forums.
Does anyone know if the Aux switches have auto shut off once the engine is off?
I was hoping on wiring a specific set of DRL fog lights to one of the Aux switches and just always leaving it on.
Is this possible or am I going to kill my battery? Any other suggestions are appreciated.
Thanks
Headsong
I think there's a diagram in the manual that tells you which ones are hot or not.
mountainbronco
I believe the ALL are switched to ignition on, so you can leave the switch on and simply exit/lock, they should just turn off.
But, I would never leave a circuit on....
TX-Hans
'21 Escalade, '13 Jeep Wrangler, '21 Bronco FE
You might take a look at the Fog Light switch thread in conjunction with activating the fog options using ForScan. It seems the Bronco's wiring harness has the fog light wires already in the harness but unused. You can connect your fogs up to the existing factory fog connections. You can buy the Ford OEM dash panel headlight switch/module that has the Fog light push button and swap it out for your current headlight switch. Then activate the Fogs in DRL mode using ForScan.
https://www.bronco6g.com/forum/threads/factory-fog-light-switch.22937/
