Shhhh! don't be saying that too loud ... I'm good with everyone thinking it's A52.I just changed from Silver to AGM. It is as close to Britney Blue as I can get.
Britney Blue?I just changed from Silver to AGM. It is as close to Britney Blue as I can get.
If that's true, it will be great! However, all the color pallet, side-by-sides, show it darker than A51, so if its darker, then it can't look like the render. I believe it to be a new incarnation of wedgewood-blue-metallic, circa 1999, hope I'm wrong.Shhhh! don't be saying that too loud ... I'm good with everyone thinking it's A52.
The is AGB on the Lightning:If that's true, it will be great! However, all the color pallet, side-by-sides, show it darker than A51, so if its darker, then it can't look like the render. I believe it to be a new incarnation of wedgewood-blue-metallic, circa 1999, hope I'm wrong.
That doesn't look bad! I will reserve judgement until I see it in person, but I'm definitely intrigued!The is AGB on the Lightning:
https://media.ford.com/content/fordmedia/fna/us/en/permalink.html?VideoId=6305889880112
Interested in what you think.
Interestingly as well, this "Azure Gray Metallic Tri-coat" is a $795 option on the Lightning (which is still available in AMB). Apparently is costs more the put on the Bronco if is the same color vs just "Azure Gray". They cut CO for A51 that looks more purple.Interesting that AGM tri-coat is $995, but HPR tri-coat is still $495. What are they putting in the AGM, plutonium flakes?
I thought FC's liked gray?Oh sweet! Another boring shade of gray...
I know, it doesn't make sense for the cost, CO was a tri-coat and was only $595 on the Bronco so maybe they'll adjust fire latter down the road to my favor.Interestingly as well, this "Azure Gray Metallic Tri-coat" is a $795 option on the Lightning (which is still available in AMB). Apparently is costs more the put on the Bronco if is the same color vs just "Azure Gray". They cut CO for A51 that looks more purple.
LOL I'm definitely not an FC, that's just a blurb on the end of the username. I'm a prior MM current CTN.I thought FC's liked gray?
Retired ITC here!
Got it, CTN's definitely don't like grayLOL I'm definitely not an FC, that's just a blurb on the end of the username. I'm a prior MM current CTN.
