B&O sub - almost seems defective?
Cold_steel
Trey
Frederick, CO
Hey all,
I have a 2 door with the B&O system and honestly I’d be happy with how it sounds… except that the sub has a very odd “popping” sound on some songs at very moderate volume levels.
I thought maybe it was trim rattling, but after I got back there with a song playing it really abounds like the sub itself is popping or maybe rubbing against something when the cone vibrates? It’s odd
anyone else with the B&o system experiencing this as normal or should I take it to the dealer?
BigMeatsBronco
Allan
2021 FE 2 door
Mine sounds great, but I did put some foam behind it. Not an easy task.
JaxGtc
I have not experienced this problem. You might take it to the dealer and have it checked.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hey all,
Hi there! Would you care to private message us with your VIN and dealership name and location? I'd like to look into this concern for you.
Stilbukn
Marty
Benson, NC
'73 Bronco, '13 F150
Mine has been great and very pleased with it. Good looking out Ford, great to see a quick response to the thread.
Scott1911
Oklahoma
2 Door BadSquatch
"Pop" or rattles/vibration? Most people have had to put things in the area of the sub to either stiffen or dampen the plastic to limit vibration. I had some extra "sound assassin" strips from a Hothead liner install. I also placed pieces of wide tape around the back of connectors in the area.
I don't think the people who tested the Bronco were listening to their music very loud :rolleyes:
Draughon
Daylon
Dallas
BMW 4-Series
Cold_steel
Cold_steel
Trey
Frederick, CO
Cold_steel
Cold_steel
Trey
Frederick, CO
I thought it was trim rattling at first, but once I got back there next to the sub I can hold all of the trim and the sound still happens- it’s hard to describe but it’s a popping sound on certain frequencies. Low to moderate volume. Any higher than that and it’s not tolerable.
jasonf
jason
california
f150
mine also does that noise . also no sound into front channels only rear. returned to dealer says no part available to replace the bo lux amp.
50Mustang
2022 Bronco
Hey all,
I have a 2DR Lux as well, and getting the exact same popping sound as you are. I've slapped the sub and panel around a few time and that would fix it momentarily.
BroncoMO
J
Kansas City,MO
Lincoln Navigator L
I have a 2021 FE 4 door and the sub / rear plastic rattles so bad I turned the sub down to limit the horrible rattle. Frustrating
Ruby22
Lisa
Ford F-350 Platinum
I have the same problem. I have had my bronco for 5 days. Mine vibrates and sounds broken.
Saltwater Native
Neal
Range Rover Sport
I just picked up bronco less than a week ago, and I am having the exact same issue.
MKZoom
MKZ
it's very possible the fasteners that attach something in that area are a touch loose and you are hearing it slide over one thread one way or the other and back again, id recommend checking the bolts behind the rear quarter panel or just bringing it to the dealer. my friends bronco was fixed with a few turns of a socket.
