Rides great on and off road, no extra stress on ball joints. SAS shocks are already dampened, like I said just my opinion.
We certainly appreciate your interest and hope we can earn your business! Feel free to reach out anytime!Apparently people have way more money than me….So anyone out there with HOSS 3.0, 4door Wildtrak, looking to upgrade to this, please PM me as I will be interested in your suspension system.
Thanks
No, it actually doesn't do the same thing. You may have gained lift with your spacer but you lost in the suspension department.Just my opinion, but I've got the SAS with a 2.5" spacer kit. Did the same thing for a lot less
I love the clear anodized option also! Helps corrosion resistance compared to raw aluminum.Clear ano option!?!? Someone in your engineering/design dept is trendy!!
I love clear ano lol
Out of curiosity, why does everyone build billet control arms out of 6061 rather than 7075? Does the 6061 handle vibration better or is it purely cost driven?
Hello All!
Just want to say that I love this community, and also introduce myself. I am Dustin Bach the owner of Bach Built Off-road and my team and I have been working hard on offering our new suspension kits to the market. We were a little behind but finally starting to make some headway and have lots to show and update as we move forward. We are currently offering a Stage 1, 2 and 3 suspension lift kits.
Our team, including myself, look forward to everyones comments as well as questions about the products as we move forward. We appreciate the support and hope to earn your business in the future!
Thanks and cheers!
-Dustin
www.bachbuiltoffroad.com
[/QUOTE
Naaaaice!! Hello All!
Thanks and cheers!
-Dustin
Naaaaice! Hello All!
Thanks and cheers!
-Dustin
Without disclosing too much about myself, you are correct, and often times unnecessarily so. 6061 is more than adequate in many applications in the defense industry, but in the commercial sector the consumer suuuure likes to see 7075 lol!7075 Is mainly used in the defense industries.
I finally talked to Fox and the sales associate I spoke with said they don't offer any higher spring rates at the moment but they could in the future. So basically, its up to the customer if they want to change out to a heavier spring. I will do some more research and see what springs would be available if this is an option.Any insight on your spring rates on the Fox setup? Will you offer options on springs to compensate for heavy winch bumper and other added weight?
Do you happen to know what the spring rate is now?I finally talked to Fox and the sales associate I spoke with said they don't offer any higher spring rates at the moment but they could in the future. So basically, its up to the customer if they want to change out to a heavier spring. I will do some more research and see what springs would be available if this is an option.
Sorry for the late response, but the current spring rate is 365lbs. Fox said they outsource the springs themselves and it would make sense to run heavier springs if you plan on mounting heavier accessories. The rep also told me you can increase 50lb without a re-valve but at 100 or more, you have to re-valve.Do you happen to know what the spring rate is now?
Thank you! 365lb sounds way too light for the fronts. Probably about right for the rears.Sorry for the late response, but the current spring rate is 365lbs. Fox said they outsource the springs themselves and it would make sense to run heavier springs if you plan on mounting heavier accessories. The rep also told me you can increase 50lb without a re-valve but at 100 or more, you have to re-valve.
In doing some research last night, Eibach does make a 700lb spring but that seems heavy to me. Hopefully this gives you some insight on the product.
-Dustin
Yes I agree, and would think it all depends on application. Trail riding with winch and heavy steel bumpers, would need an upgrade to a heavier spring. I will do some testing with heavier loads on these shocks as well and give my own feedback.Thank you! 365lb sounds way too light for the fronts. Probably about right for the rears.
