Base manual transmission on 33’s
Boltstop
Rudy
Idaho
69 Bronco 302
I just picked up my base standard 5 days ago and miles per hour matched my Google maps speed , when I put on 33's there is a 3 mile per hour diference so 33's run 3 miles per hour faster than odometer speed , the feel is fantastic this base bronco was designed for 33's in my opinion .
Boltstop
Rudy
Idaho
69 Bronco 302
By the way those are black diamond upgrade take offs I found for $800 nice
bradcd
Brad
Saab 9-3
I've got the same Thule roof bike carriers. Can you actually lift your bike up that high to strap it in? Even with running boards on my 33" tires I don't think it'd be worth it to mount my Thules on the Bronco and am now looking into tow hitch mounted carriers.
Straightbase
Massachusetts
2 door Base MT
Yeah it is possible. I use a two step ladder and throw the bike right up there. Tires just went on and I havent gone on a trail ride since hoping the extra 1-1/2" isnt a prob
bradcd
Brad
Saab 9-3
Well I'm curious to know what kind of issues you face if you don't mind reporting back later. Routes you must avoid due to height clearance? Difficulty in raising a 32lb MTB above your head after a sweaty run? Will other riders make fun of you when you bust out a two step ladder in the trail parking lot? Lol
Straightbase
Massachusetts
2 door Base MT
Been putting bikes on top of my trucks for years. I guess it never really crossed my mind what other people were thinking when I roll up. Around here all I have to do is stay off of Storrow drive and I should be clear of bridges. Other than that I just stay out of drive thru lines
Gnomad
Harbor Springs
Base 2 dr, 7MT EG
Ford must have geared the MT for 32=33" tires, and installed the stock tires as placeholders until the owners found their actual tires. I went with 285.75/16's and found the gearing went from short to perfect.
Also plenty of go on the freeway, we made a bit of a pilgrimage to the original Ford factory in the heart of deepest failed industrial Detroilet from the NoMi area and frewway speed was not an issue at all. Fuel economy takes a big dump upwards of 75-80 for sure.
Little Foot
Buffalo
So Stanley finally got his new shoes… Actually ordered Toyo Open Country but my local shop was shipped Geolanders instead and they offered me the Geos for the same price as the Toyo's. I took the deal. 6000 miles on the stock base 30’s and it always felt like 1st and 2nd were way too quick. The 33” tire has completely changed the feel of this truck. If I knew more about gear ratios I would probably understand what’s happening but I swear this Bronco was made for the 33” tire on the MT. Loved this thing already but wholly F••• what a difference.
Your Bronco looks great!!!!
Does your Bronco have a rear locker? If not, @Bronco_joe just swapped his rear axle out of his Black Diamond, which comes with the rear locker and 4.46 gears. I’m sure he would give you a smoking deal.
Straightbase
Massachusetts
2 door Base MT
No this is a base Base only thing I added from factory was keypad and floor liners. Not ready to get into a project of that size quite yet.
Little Foot
Buffalo
I can understand that. I just figured I’d float that out there since you are already running 4.46 gears. Nice little upgrade while using factory parts 😁
I definitely think that the Base is vastly underrated for it’s capabilities.
Straightbase
Massachusetts
2 door Base MT
No question in my mind. This truck is everything I wanted it to be and the change in tires has only made it better.
Clarke
Canada
2022 Base Bronco
I want to get this same size tire! Do you mind taking some pictures directly from the side and directly from the back and front? Thanks!
