Resetting TPMS on manual transmission Bronco?
EveryDayBronco
Motorcycle
I found the video for resetting the tire pressure sensors but I think it’s for automatic’s. I tried on my manual and it didn’t work!
Does anyone have a procedure for resetting tpms on manual Bronco?
Thanks,
Here’s the vid I found, maybe I did it wrong I don’t know??
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
I don't know. Mine have never needed reset. What are yours doing, or not doing, that requires a reset?
kodiakisland
Arkansas
I got take off wheels.
It didn't pick them up after several miles of driving? I wouldn't think the process would be different for a manual than the auto, but who knows.
mpeugeot
It took like 2 days for my take off wheels to reset my TPMS... I was pretty annoyed at first. It did finally wake up to the new tires and wheels.
JT58Bronc
JT
Fl
2022 Bronco, 2021 Miata track Edition
I had to buy a tool to do this on my C6 Corvette when I bought aftermarket wheels. It was not that expensive although it is older technology being a 2006. With the tool the reset was instant and took like 5 minutes to do all 4 tires. I am not sure about the Bronco. I see so may have aftermarket wheels so it is probably just as easy.
zombie
New Brunswick, Canada
2021 Bronco Badlands (7spd) 2022 Mustang GT PP
Yeah, unless I'm misunderstanding your situation, you need a ford TPMS trigger tool to get the vehicle to learn the new sensors.
BenBronco
Alabama
2011 F-150 and 2020 F-150
I replace my wheels/tires at Discount Tire. They installed new TPMS sensors. The tire pressure light was on but the tech said the Ford sensors are auto learn and would reset in a couple of miles. No tool or procedure needed. He was right. The light went off before I got home. I have a manual transmission.
jacknifetoaswan
JR
Charleston, SC
2016 Mustang GT/PP
EveryDayBronco
Motorcycle
Sorry to hear you're having issues with the relearn @EveryDayBronco!
In your information display screen, is there a Tire Monitor menu option?
Not a menu, just gives option if I want the tire pressure screen on my scroll if I can call it that.
There’s another video, older, that shows the system “learns” each tire by letting air out until the horn honks. This would be instead of using a special tool.
‘21OBX
Ken
90Bronco19
2022 bronco outer banks
When I bought my takeoff wheels I installed them and drove down the freeway. The bronco picked them right up. If they are not happening you may not have sensors in the wheels. If they are stock ford sensors they are already the correct frequency. Even on my new aftermarket sensors all I had to do was drive above 55 or so for a few minutes and they woke up.
E. Davis
Charlotte, NC
2019 Mustang GT Velocity Blue
Drive it 10-20 miles. As long as they are ford sensors, and the seller didn't take the sensors out before selling, they will learn themselves. No tools needed.
That said, there may be a chance the seller took the sensors out and put regular valve stems in.
EveryDayBronco
Motorcycle
Yes, there's chance the seller kept them but I can't see any signs that the tires were on a machine!
I'm planning to bring it to tire shop tomorrow to swap the sensors from my factory wheels. I'm just hoping I can spare myself the 4 hours that that's going to take out of my weekend!
Here's vid that shows how to get the system "learn" without a special tool.
E. Davis
Charlotte, NC
Yes, there's chance the seller kept them but I can't see any signs that the tires were on a machine.
You don't need to do this as of about 2016 and newer. The ford learning system has been automatic on all cars for several years, as long as it has compatible sensors on it. Even when you rotate, the car will re-learn the position of each wheel after a short drive.
