Base manual transmission on 33’s
Straightbase
Massachusetts
2 door Base MT
So Stanley finally got his new shoes… Actually ordered Toyo Open Country but my local shop was shipped Geolanders instead and they offered me the Geos for the same price as the Toyo's. I took the deal. 6000 miles on the stock base 30’s and it always felt like 1st and 2nd were way too quick. The 33” tire has completely changed the feel of this truck. If I knew more about gear ratios I would probably understand what’s happening but I swear this Bronco was made for the 33” tire on the MT. Loved this thing already but wholly F••• what a difference.
Straightbase
Massachusetts
2 door Base MT
I may be biased but it feels like a whole new truck
Straightbase
Massachusetts
2 door Base MT
I hear you on the E load. Still early for me hope it doesn’t become an issue. I can say it feels fine so far.
HoosierDaddy
Indiana
Looks pretty freaking tough !!!!
There a good many people that think the 33 is ideal for the 4.46/7mt combo.
I overshot with the 35's on my 7mt Base, it's still easily drivable, but you can tell it'd be happier on 33's.
tractorcrusher
Curtis
DFW, TX
The two door is definitely in its prime with 32s-33s... I went to 35s and it was immediately not as sporty. Still thinking about getting a set of takeoffs and going back to those for daily.
indio22
Chicagoland, USA
The manual Sas with stock 34.4" tires comes with 4.7. 4.46 vs 4.7 seems such a small difference, I think only a couple hundred rpm? Is it really that much of a performance difference?
If 4.46 is a dog with 34.4 tires, you'd think 4.7 would not be much better.
Maybe it's also partly the case that some of you running aftermarket 35" tires, have sufficiently increased tire weight with your selection, in some cases 70lb tires? In comparison, the stock Sas tire is only 52lbs.
Someguy
CNY
CX-5 Turbo/Indian Scout Bobber
This is perfect. I got a Black Diamond so I could have a manual 4 door, but on certain colors I love those silver steel wheels even more than my black ones.
How hard is it to get your bike up on the roof? My Bronco is a soft top so I'll be using a hitch mount, but it was always a pain loading the roof basket on our 4Runner and that had steps.
indio22
Chicagoland, USA
A simple calculation:
4.46 (differential)
35" (tire diameter)
65 mph
2858 (direct 1:1 transmission drive)
4.7 (differential)
35" (tire diameter)
65 mph
3011 (direct 1:1 transmission drive)
So the difference in engine rpm for the above, is only 153 rpm. For that reason, I'm surprised some of you are finding such a difference in vehicle performance between 4.46 and 4.7 differential gears. Is there some other ingredient I'm missing?
Straightbase
Massachusetts
2 door Base MT
I use a two step ladder and its not too bad. I am always worried about dropping the bike but as of now no real problems.
HoosierDaddy
Indiana
4.46 (differential)
35" (tire diameter)
65 mph
4.7 (differential)
35" (tire diameter)
65 mph
I've wondered about this also.
I need to run these on a gearing comparator and see what it churns out.
(Grimmjeeper.com has a really nice one)
Knowing what I know now, my "seat of the pants" experience, I would not be surprised to find that 5.13's would be a better gear for the manual and 35's.
I can only speculate why Ford doesn't do that.
HoosierDaddy
Indiana
LOL,
So, the factory gearing I hate in the low gears ALMOST nets me the rpm's the motor likes at Interstate speeds.
( Mine seems to like 2600/2700)
Ratios needed to get 2500-ish at 78mph (6th gear)
(30.1 )30" tire and 4.46 = 2512
(32.8) 33" tire and 4.70 = 2426
(34.5) 35" tire and 5.13 = 2517
(36.5) 37" tire and 5.38 = 2495
To put the motor where I think it is happy, you have to move the gear ratios up one position .... so 2647rpm w/ 30" tire and 4.7 :oops: wtf?
I need to dork around with this some more...
Interesting, comparing the 1st couple tranny gears ... 4.46 with 30.1 and 34.5 tires ... there is only two or three mph difference at 3k and 4000 rpm ... yet seat of the pants , there is a world of difference!
By comparison...
4.46/32.8 charts out the same as 4.7/34.5
Hmmmm..... verly interesting.....
