MaverickMan
Shane
Thank you for sharing.. Is that in rock crawl mode? I've gotta say it is disappointing if the gearing is so tall in low, way too fast for serious rock work just from watching.
Auto trans problems. 4cyl mansquatch for the win!
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
I think it comes down to driver experience with skinny pedal if you compare this to Vaughn Gitten Jr. or Loren Healy videos.
Roadkill
Susanville
2021 First Edition
Ill have to look for them. Thanks
BroncoBoy22
Laker Land
'11 Mustang GT 5.0
Not trying to rag on the OP because he’s already done more wheeling with his Bronco than I’ll ever do in mine 🤣 but no, you can be way easier/smoother on the throttle from my experience at off-roadeo.
Plus if throttle control is an issue (it won’t be with a little practice) you can always use trail control or one pedal drive.
Oscargrouch323
Oscar
Los angeles
ac-fab.com
2022 bronco
I had a bit to much air in my tires Soni was spinning a lot. My bronco does not have crawler mode
Oscargrouch323
Oscar
Los angeles
ac-fab.com
2022 bronco
Yes I could of used crawl control but it just feels like I'm cheating. I did have to much air in my tires and didn't have enough grip. I'm still learning this truck and it's always trial and error. I run my crawler at 10 psi with beadlocks and rarely spin a tire. Until I get the beadlock rings for this one I won't go below 20psi.
Oscargrouch323
Oscar
Los angeles
ac-fab.com
2022 bronco
I like your sliders I’m guessing frame mounted? Hardly any good sliders out yet for the bronco mostly step style ones.
Yes I made them to bolt to the frame. Body mountain just wouldn't the the abuse.
Sparkherd
Sparky
South Central Texas
www.sparkherd.com
Lifelong Ford guy.
Check out a video I made. Showing my 2021 bronco base sasquatch with 1 inch leveling and 37" ko2 tires
Ya'll saw the vid with the guy in the Blue Bronc?
Foot flat on the skinny pedal?
Stock truck with big ol tires bouncing all over the place?
Two busted tie rods?
Now see the guy in the Red Bronco?
Foot NOT flat on the floor?
THAT's how you do it!
De Brus
De Brus
Washington state
I don’t think I’ve seen the video that led to that destruction. Please share!
