(Before I accept the car) Is this normal for Bronco?
jkoldboys
Jake
Bronco 4door
Hello! It's been a while since my order submission and finally I'm going to receive my Bronco.
Hard top 4 doors Outerbanks, and today I got a phone call from dealership my car is ready to pick up. And I went there to inspect my car before I receive and I found those sealing (between hard top and window) defects (?) and those are pretty bothering me. So, I'm wondering this is pretty normal for Bronco or it is some factory defect I should report before receiving car. Thank you.
Phil
Phil
2022 Tesla Model 3 LR
At a bare minimum I would have them write it up as a defect and get with Ford on this Would rather have the note in the system than have something happen later and then they try to blame it on you good luck!
da_jokker
Jeep Wrangler JKUR
Well the tops are still under question, and Ford has stated that they are going to replace them.
Now whether or not they do, or if they think your top is already the "replacement" It is hard to say.
Maybe have the dealer run it through their car wash and see if it leaks.
7.3ltr bronco
Chad
Schereville Indiana
01 f350
I got mine and took it through the superwash the next day. No leaks but my passenger side door on the backside kicks out a little bit like it needs adjusted. It is not flush with the body the only reason I figured it out was I had body graphics put on and the body guy commented on it. But anyways my hardtop looks prettyuch the same.
mybikeisred
Paul
Carmel, CA
F250 Powerstroke, Grand Cherokee
Mine doesn’t look great, but a little better than that.
AZ_BRONC
Tempe, AZ
‘17 4Runner, ‘16 BMW 328i, ‘96 Stang GT, ‘19 Mini
I was going to comment about you calling it a car and then realized it's an outer banks. Carry on.
If it has SAS, aux switches and a modified bumper, plus five minutes with FORSCAN, and his OBX has everything your Wildtrak has except for a sticker, and probably has a nicer interior too. And side steps and more painted trim. 😛
