Bluetooth - Apple Car Play Spotty....Especially when not moving
USASAIL
St Petersburg, FL
Volvo S90, Chevy Suburban, Base 2Dr
I've had some odd issues with Car Play off and on. If you plug your phone in before wireless carplay hooks up it won't pull up carplay or it's not stable.
But the strangest thing happened recently. Bluetooth, phone, music from itunes, or Pandora all worked fine, until the car stopped moving. At a stoplight it would just cut in and out. Once I started moving again it was fine.
Anyone else had issues?
Aonarch
North GA / MT
‘23 Bronco OBX 2DR Lux 2.7, ‘16 Corvette Z51
My Carplay has been finicky since IOS 17, so hopefully an update will fix it from Apple. I know this because my Audi is having the exact same issues after IOS 17.
Is your stop start on and engaging when the problem happens? It could be a voltage drop issue.
I believe you can factory reset your infotainment though, try that.
USASAIL
USASAIL
St Petersburg, FL
Start Stop is a good thought. it might be.
roadsterlife
Freddy
MA
Bronco Raptor, Miata, BRZ
I have to actively remember not to plug my phone in. My old audi had carplay only when you hooked it up so trying to get rid of that muscle memory has been hard. Other than that, no issues at all with carplay (I am not on IOS 17 yet)
Denis
Seattle
GTI
Same here, most of the times have problems starting Carplay wireless
And only reason why went with Lux is to have wireless Carplay and charging
We know that charging is not working, now Carplay started to make problems too
I probably need only one bad day, and will just sell it
TerryVester
Terry
Ohio
2022 C8 Corvette, Jeep Wrangler, Linlcon
I have not had any problems with my carplay
