Triceratops
10 speed Huffy
@Doetsch Off-Road How far up did the coilovers alone lift the two door before the bigger tires? Did y’all measure?
broncohopeful
Hyundai, 22 Bronco
Beautiful!
P52Ranch
Bryan
Oklahoma
2DR 7MT Badlands, F150 Lightning, New Holland 4030
What is the total $ for this upgrade. Is it offered as a package price?
peterh
ny
jeep wrangler jlu 2018
offset on those wheels is what?
Aztec1382
Sam
F350
How much for the arb kit with the bracket
Triceratops
10 speed Huffy
I have a very similar set up (different brand parts) and Doetsch did my 2 door as well, lift was just shy of 3”.
thanks, I have a set of icons going on next week. Not the biggest fan of going over 2.5 inches but definitely don’t want to go over three. The two doors have less weight and therefore get a higher lift. Might have to play with the preload. Normally people do that to get more height, I want to reign it in. We’ll chat with icon when we see what it does.
TexAZ
AZ
F-150
Yeah, keep in mind the bumpers, winch, sliders, skid plates, etc. if that’s in your plans.
moab6g
What is the offset you choose for your rig with the Icon "new beadlock tec" they have 2 option
0 offset or +45 I think ,,,,, I have a 2 door and also interest to do the same
Also want to know more about the Icon how much you like it
Thanks
Doetsch Off-Road
Doetsch Off-Road
Todd
Chandler, AZ
www.doetschoffroad.com
2021 Badlands 4dr, 2021 Wildtrak, 2021 Rubicon 392
Thanks
These are a 0 offset, thats the way you want to go. The new Icon technology is great. Its DOT approved for the street, and bridges a gap between a traditional non-dot beadlock that most dont need, and a regular street wheel. WIth these, you can air down safely in to the 10-12psi range without worry of fully losing a tire from the bead. Icon, as always is a trusted offroad brand and produces high quality parts. If they are on your radar...I wouldnt give it a second thought. Let me know if I can help out.
TenaciousEJ
EJ
Greensboro
Bronco Sport
“Up front, we installed a Rough Country hidden winch mount which utilizes the factory steel modular bumper, but allows for a trick spot to get a 9500lb winch installed where the factory lower skid plate sits.”
Can you explain this a little better? Does it replace that front steel bash plate? Mount over it? Do you lose any clearance with it mounted there? I guess I’m a bit confused what you meant by “trick spot.” And what winch did you use?
Doetsch Off-Road
Doetsch Off-Road
Todd
Chandler, AZ
The RC kit has its own skid plate, and the winch (in this case a RC 9500 synthetic) fits snugly deep inside it. Overall vs a standard ford steel skid plate there is little to no difference in overall clearance.
