4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
You get a $75 mail on rebate from Baja
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
8oncoPete
Pete
Connecticut
2023 Raptor and 2024 BMW i7 / 2019 BMW X5m
Tye
Tye
San Francisco
Porsche GT3, Landrover Defender V8, BMW X3 Msport
Looks great. I have the same 6 LP4 on the bumper but did a custom wiring harness to wire it differently than you did. Question I have, why did you choose to not go with the LP4 for the ditch lights? They have covers to block the side emitted light.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
How did you wire yours?
Tye
Tye
San Francisco
Im of the school of I'd rather go overkill then underkill, thus I have dual 10 gauge wires feeding 3 LP4’s each parallel to each other, all going to relays and then directly to the battery. I use the Aux switch as a trigger switch to turn the lights on, and the backlights are connected to the parking lights through a marker adapter, so whenever the marker lights are on , so is the backlighting. No extra switch necessary. Also, everything is plug and play, no cutting or tapping of wires.
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Gotcha. Our system was designed so that it all daisy chains together.
The harness provided will handle safely up to 45amps and the lights put out 40 amps. The relay is rated for 80a and the fuse is rated for 60amps. The harness uses 10 gauge wires.
I mean what you did isn't bad, just not necessary :)
If you don't want the daisy chain harnesses we sent, can I have them back. They cost quite a bit of $$ (that's $140 worth of wiring harnesses we sent over)
raptorbill
bill
STERLING HEIGHTS, MI
2020 GMC Sierra AT4
Do you think this kit will work on the capable bumber if i just drill the holes in the top of the bumper?
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Anything is possible if you make some holes, but this is designed as a bolt-on kit for the HD Modular.
raptorbill
bill
2020 GMC Sierra AT4
yeah i just went out and looked. the capible bumper sits closer to the grill and this would need cutom brackets. But its got me thinking.
8oncoPete
Pete
Connecticut
The XL80s throw more light and was concerned about the side light. I didn't want to have to use the covers. I went back and forth on this decision and finally landed on doing the XL80s, but now you have me wondering if I should have done the LP4s....
Tye
Tye
San Francisco
You cant go wrong with either, and ive been back and forth on this as well. I wish baja would extend the backlighting to other lines, which is why im leaning toward the lp4 on the pillar so that all my lights have backlighting. The lights still look good even with the covers installed:
Ford Bronco Bronco Raptor With Proper Lights Setup DF03F295-E762-48EE-A660-A51C28707B92
