Just walking around. This was not a drivable prototype. Sadly.I wonder if the vehicles are even going to be moving in the video or if it’s just a walk around?
Yes, working on a walk around now. Should be out today.Sorry.. I meant, are you doing a video walk around or something?
Doug Demuro has set the bar for this Justin....Just walking around. This was not a drivable prototype. Sadly.
huh. i wonder how they got it into the trail at filson...Just walking around. This was not a drivable prototype. Sadly.
Because the handler is the only person allowed to drive it. Super lame. The engines aren't factory, so it rolls, but they don't want reviewers reviewing an engine that isn't finished.huh. i wonder how they got it into the trail at filson...
I think the bar set by that video is at different levels based on who you talk to.Doug Demuro has set the bar for this Justin....
At least my screen and comfort controls worked on my prototype...Doug Demuro has set the bar for this Justin....
no that would only be correct if it was a wrangler and an fj... i just cant find that memeHis and hers. Getting ready to make babies.
oh, i thought you meant it didn't have an engine... thanks for the clarification!Because the handler is the only person allowed to drive it. Super lame. The engines aren't factory, so it rolls, but they don't want reviewers reviewing an engine that isn't finished.
What do you mean these 35's are bigger than the Sas 35's?Keep in mind that is a non SAS Bronco with aftermarket 35" tires (bigger then the SAS 35" tires). Without a lift you are going to run into some major tire clearance issues off road (like having that Jeep drag you out kind of issues).
I'll warn you. Brace yourself. Some here can be ruthless for, really, no reason.Yes, working on a walk around now. Should be out today.
I believe that cyber orange one had 37 inch tires on it and a lift.Visually the Bronco looks like it need a bit more height to it.
Going back to photos the original Cyber Orange one looked massive and tall, not so much on the others we have seen since.
