BroncocnorB
Paul
1965 Cobra,
I want steelies too. Hope I’m not too late to the party
mpeugeot
Are you able to change the tire size in the trucks computer so the speedo is accurate?
Yes, with FORSCAN, but it's a slight bit of a pain in the ass to get set sometimes.
mpeugeot
These are my off-road tires, so no TPMS sensors, no need. However, hopefully I will be use Forscan to disable TPMS warning on the dash when off-roading.
And I disabled TPMS. FORSCAN did a great job with disabling the TPMS, the tire size was more challenging, as sometimes the reset takes a few attempts (you have to do a relearn procedure to clear the codes).
Ford Bronco Bye Bye Steelies. Hello RTR Wheels on my 2021 Bronco Bronco M3
As you can see the Satin Charcoal and Carbonized Gray look perfect together!
7722 Bronco
Kentucky
2020 Explorer ST/ 2019 F350 CC DRW 4x4
Picked up a set in satin black during black Friday sale. $927 for 5, 17x9, +0 offset to my door.
BroncoAZ
Mitch
2021 2 Door Badlands manual, 2021 Tacoma TRD OR
CantBstill
Nathan
Georgia
1966 Ford Mustang
Can you post the link to where you got your tuner style lug nuts? Trying to find specs on the RTR website as to what they recommend but, it doesn't really say.
DEC
Derek
SoCal
BMW 640, Mustang Bullitt, Mazda 3, Honda Accord,
This has been my favorite setup I’ve seen. Looks great on Race Red.
Now that my Bronco is close to being on the way, I’m looking for how this setup has worked out for you? I’m guessing no issues?
It also appears that the RTR wheel in black is not available at this time, bummer.
BigBronco1
BigBronco1
Mamaroneck, NY
2018 Silverado, 2021 XC90
I've got 4,000 miles on the Bronco (don't use it much in the winter). So far no issues and I still get excited every time I look at the Bronco. Very happy with everything overall.
KitsBronco
Tom
Vancouver, BC
Triumph Street Scrambler
Said goodbye to the Steelies today in favor of the RTR tech 6 wheels. I plan on keeping the Steelies for the winter. I wrapped them with 285/70/17s (33s)no concerns with rubbing.
the +30 offset on the RTR wheels gives a slightly more aggressive stance. Very happy with the look.
Cost:
Tires: $1350 on tire rack
Wheels: $1100
Mount, balance, new TPMS stems: $600
So all in $3k
Looks sick! Going with the same set up for my cactus grey OBX. What size lug nuts are required for the Tech 6 wheels? Thanks!
BigBronco1
BigBronco1
Mamaroneck, NY
The RTR website says 'tuner style' lugs. I called RTR and was told 14 x 1.5 lugs which I then bought from CJ's Pony parts. When I got them, they didn't fit.
I called RTR and they said it's 12 x 1.5, they also gave me a $100 credit which was unexpected and appreciated. CJ's took back the wrong lugs.
And my mechanic ended up using the lugs that came on the Bronco - he said they seated fine in the wheel and even though they're silver / wheels are black, they sit down inside so you don't see them.
So long story short, you can probably use what is on the OBX but if you want to I would buy 12 x 1.5 which is the correct size. They cost like $75 from CJs. Send me a pic when on, Cactus Gray was our second choice.
KitsBronco
Tom
Vancouver, BC
Thanks for the detailed reply! Nice to see they helped you out after giving you wrong info. Will definitely send you a pic once it arrives..could be a while lol
timstrong20
Tim
Georgia
2010 Toyota Venza and 2020 Honda Civic Hatchback
Cost:
Wheels: $1100
So all in $3k
Looks nice, I like the white lettering.
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
Honestly these wheels look almost identical to the OBX ones when painted/powder coated black.
edit: to be clear, I think they look great. I’m just saying you could Powdercoat and get almost identical appearance for cheaper.
