Ceramic Pro and detailing AMA
Compta38
Alabama
Ford Fusion
I was planning on not having the dealer clean my Bronco then doing the wash claybar and adding one of those graphene sealers myself. I don't care to do a paint correction and honestly had a bad experience with an orbital buffer and my Trans Am in my youth so I do everything by hand anyways. With all that said with all these graphene products what would be the under $100 go to product?
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
Following. I’m trying to understand the various brands and how much value you get with the more expensive products on a white vehicle.
appreciate OP’s sharing
mbagne
Matt
Placentia, CA
Mach-E GT
I plan on a partial vehicle wrap. Does ceramic coating, done professionally, go on top of the vinyl wrap? Will ceramic coating work as well and last as long when on top of a vinyl wrap?
Pocketsand007
Ian
Montana
Honda
It all kind of depends on how many defects there are on the car when it’s unloaded. If you are looking to do everything by hand And want a good “bang for your buck” ceramic product I’d go with Hydrosilex. It last longer than anything off of a Napa shelf and you get A good shine and protected surface.
Pocketsand007
Ian
Montana
Honda
Following. I’m trying to understand the various products and how much value you get with the more expensive products on a white vehicle.
Thanks for following and I appreciate the compliment! There are 2 different products when I come to ceramic coatings. There consumer grade, which is something you can just grab off the shelf. Then you have professional grade which is product only a certified tech can install. Ceramic pro (the product I work with) help create a long lasting barrier to protect your paint from mud and dirt, it makes the surface super smooth and there’s less friction, it makes the car hydrophobic (water doesn’t stick your car easily), protects the paint from UV rays, and makes washing you car easier (tat and road grim doesn’t stick to the surface that well). Your white vehicle will be really shiny but it might not be as shiny as say a black or darker colored vehicle. You’d primarily get Ceramic pro on a white vehicle to get those protective properties.
Pocketsand007
Ian
Montana
Honda
Depends on what product you use. I know ceramic pro makes a specific coating called ppf and vinyl. That coating is made specifically for wraps vinyls.
JessD05
Jessica
Boerne (say it burn-eee), Texas
GMC suv
@Pocketsand007
Hi Ian
My Bronco is on a train en route and I am reading about rail dust. Based on what I’m seeing this is not something the dealer takes ownership of to remove. And it’s
Easier to remove if the dealer leaves the car alone, no detailing. Are those statements correct?
In the Link below the person mentions using a Rust remover? I didn’t see mentioned in your comments. Do you recommend this and if yes what type/brand should I purchase?
https://www.bronco6g.com/forum/threads/đź› -1-3-22-build-week-group.27813/post-1192079
Pocketsand007
Ian
Montana
Honda
@Pocketsand007
Hi Ian
Thanks for commenting! Yes a iron remover is something that I would recommend! It is a pivotal chemical that use during my prep phase with all vehicles. As far as what brand you should get really depends on how much you want to spend. My recommendation would be carpro ironx. It is simple yet super effective at releasing the iron spots! When using iron remover spray it on the exterior of the vehicle and let it dwell (sit) for a few minutes then spray it off. To answer your other question for me, because of my line of work, I prefer if the dealerships recon team doesn’t touch the cars exterior. They will likely cause more harm then good.
ELKS1
Ohio
2006 F150 1977 Bronco
What product should I use to clean and protect the upper door seal on the outside of the door on a 22 Bronco? It has a rubber texture and I would like to coat it just not sure if a plastic coating will work or if I can use a regular paint coating on it? Also what are you using on the hardtops for a coating?
