Made some chase lights. I didn't liike what was offered so I modded some suction cup lights and covers for the rear window hinges.
Can you offer more info? Steps you took, wiring, supplies needed, etc.? That is unless you’re considering making it proprietary and make a profitMade some chase lights. I didn't liike what was offered so I modded some suction cup lights and covers for the rear window hinges.
I wish I would have made a video. I bought some cheap chase lights off of amazon, they didnt work. so I bought some covers for the hatch hinge covers, disassembled the leds from the housing, keeping the controller(cigarette lighter switch). Sandwiched the lens of the led on the outside and the leds on the inside. Routed the wiring along the top, Crimped the wires, tested.Can you offer more info? Steps you took, wiring, supplies needed, etc.? That is unless you’re considering making it proprietary and make a profit
I saw someone made one on amazon, but the white back up lights were on full time until the brake was applied, then it would turn red. Might have been easier to purchase that one and modify the white leds to amber.How ironic, I was just thinking yesterday evening how I haven’t really seen any third brake light replacements that could be doubled as Brakes, reverse and Chase, the brackets already there to modify from and it’s high up already too.. seems like a no-brainer to make one.
Rigid Industries makes one - It replaces the 3rd brake light and puts it essentially in the centre of the spare tire, so slightly lower than OEM.How ironic, I was just thinking yesterday evening how I haven’t really seen any third brake light replacements that could be doubled as Brakes, reverse and Chase, the brackets already there to modify from and it’s high up already too.. seems like a no-brainer to make one.
...not bad but can you remove the branding? no thanks.Rigid Industries makes one
That was one of the turn-off's for me as well. I ended up going another route, but I'm sure with enough time, effort, and money, anything is possible!...not bad but can you remove the branding? no thanks.
