TheGoodBadUgly
LA
a truck
Hard to explain. I might relate it to the sole of a work boot. It has give to it but it's not hard like a plastic, but also not floppy and limp. It holds its structure even when out of the vehicle.
Here is some pictures and a link to an install being performed in a Wrangler JL 2dr.
Armorlite install part starts at around 4:51
Here is the fiber insulator, it is a waterproof polyester, basically recycled plastic. If you swamp it, it allows for a breathability to allow the factory passive drains which are already in the Bronco to shed any rogue moisture.
very cool....any stats on how much noise reduction is achieved with the flooring? Thanks!
Do all Broncos have drain holes ?
I didnt order mine with drain holes, idk if they are under the carpet
Yup you still have them under there.
Teke
Colin
Indiana
01 Mustang Cobra
I will just go ahead and remove the part numbers from the OEM washout floor in my build spreadsheet. Can't wait to pick this up.
Giddyup Buttercup
2022 Ford Bronco
This will be cheaper than cleaning my 2-doors carpet
Tooold
Guy
Here
65 FB, transit awd duel sider, flex 3.5L, BaseManS
2-door customer here. Can't wait
mdk100
Los Angeles
Porsche 911, Cayenne, BMW X3e, 2 door BaseSquatch
Just got an email with pricing and web links for 2 and 4 door! Says it will be available soon! Shows $728 for either size (might be a placeholder). That’s a very reasonable price.
Hopefully, we’ll see a prerelease notification and maybe pricing here. I just want the first shot at ordering! @Armorlite_Kail ?
Ford Bronco Coming soon: Armorlite replacement flooring for 2dr and 4dr Bronco IMG_0929
CM81
NA
got the email to. Hopefully can order soon
Armorlite_Kail
Armorlite_Kail
Kail
Austin, TX
23 Bronco 4dr WT, 18 JLU Wrangler, 18 JKU Wrangler
Hey everyone, we are done with machining the tools and are running trials this week. Price you see on the site is the price we intend to carry at, we will run a launch sale at 10% off.
We have our finger on the button as we do the fit ups this week and if we don't have issues we will make it live. We hope to have product ready to ship next week.
Disclaimer: Things happen and even though I am optimistic we can deliver, if something isn't right we won't be giving you an imperfect floor.
Armorlite_Kail
Armorlite_Kail
Kail
Austin, TX
One more thing I want to be clear.
We did not make a cargo mat. Plenty of people make cargo mats. Our flooring is a replacement for your carpet or oem washout floor. Until we have a replacement solution for the cargo area that is an improvement from what you can already purchase, the floor is all we will carry.
I am open to hear what you guys want out of the cargo section.
Yeah there are plenty of cargo mats. What I would like to see is the entire deck replaced - dirt/pine needles/doghair/sand - it all still gets underneath a cargo mat somehow and into that carpet. And when it gets wet back there... just have to pull the mat until it dries.
All the existing products I know of just go over the top of the carpeted deck. You still have the crappy carpet to deal with underneath it.
So yeah, not looking for another cargo mat - I totally understand that, it wouldn't offer any value. But let me replace the entire cargo deck piece with something that is rubberized instead of carpeted and I'll throw my wallet at it.
There's also that stupid hinge piece that clips on the rear seats that has carpet on the backside of it - the one that rotates with when you lower the rear seats to cover the gap.
raqball
Kris
WA
2023 Ford Bronco Badlands 2DR
I had BedTred in my Jeep JK and it was absolutely terrible, fit and finish wise... Ripped it all out and had the entire floorboard from front to back sprayed with Line-X.. Worked great but had it's issues as well..
Looking forward to seeing the 2dr version of this kit out in the wild but I'll wait a bit before ordering to see some actual on hand reviews.
I currently have the rubberized flooring in my Badlands 2dr but this sound like a better option..
broadicustomworks
Hanging Rock, North Carolina
Exactly this.
No matter how much a mat protects against containing some debris and abrasion, the underside of the cargo flooring is that speakerbox-carpet-esque feel. It gets wet, it stinks. Dry it out, no stinky. Least bit wet again, stinky.
Something rough and ready, able to handle some occasional/accidental/copious precipitation without mildew-smell.
It could be as "simple" as using the factory flooring as a template, only making your underside the same material as your flooring underlayment. Although we all know it would not be an immediate thing. Would require some R&D, some tooling, etc.
GMC
TN
Maverick
I'm planning to install the oe rubber cargo tray.
https://www.bronco6g.com/forum/thre...r-floor-tray-front-to-back.63127/post-1751356
GMC
TN
Maverick
Hmm. Have any actual pictures of it? Hard to tell from the parts site exactly what this is.
If this is the entire piece - that may be exactly what I was looking for, although $867 MSRP is a bit steep.
I don't, but @Ducati1098 is usually pretty accurate. It appears as the part number for the 2 door has been superseded. I'm seeing 2 door around $255 and 4 door $575
https://www.tascaparts.com/oem-parts/ford-mat-floor-m2dz9813046d?c=az0xJnE9TTJEWi05ODEzMDQ2LUI=
https://www.tascaparts.com/oem-parts/ford-mat-floor-m2dz7813046b
