CV axle BUSTED
da_jokker
Jeep Wrangler JKUR
We have a stock Badlands and our CV joint sheared completely, dealer mech said he's never seen anything like it. :oops:
There have been a few reported incidences where the CVs were not properly seated all the way from the factory and have done some weird things because of it. Quality parts and quality assembly is definitely not a priority.
BisSilent
TrailerPark
Mustang
Here is another one that the clamp came off!!
Ford Bronco CV axle BUSTED 20230823_174321
Aonarch
Jack Hoff
MT
ā€˜23 Bronco OBX 2DR Lux 2.7, ā€˜24 V60 Polestar
First off. That isn’t how MM works. MM is for aftermarket replacement parts, for example if you put a Moog tie rod on your Bronco, Ford can’t void your warranty because you didn’t use a Ford part.
MM does not apply for a 3ā€ lift, or any otherā€performance ā€œ part that doesn’t meet factory design specs.
My guess, the installer damaged the CV during the install you have to remove the axle nuts and press out the CV from the spindle, during install.
