DD Hitchpod SSC1 Kit installed
bomchet
Bom
northern va
2014 dodge durango
So for the rest of us who didn't wait for the 7 pin harness b/c it was limited, this won't work at all?
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
I’ve used the below linked light in the past. Uses the 4-flat connector. A bonus is - you can buy one for every member of your family for less than the price of one DD light :D
Note that 4-flat plug specification does not have a provision for reverse lights.. So to use the reverse light function you’d either need to use the 7-way plug (if you have it) or tap into your taillight backup wire if you don’t.
https://www.amazon.com/Bully-Brake-...039989&sprefix=hitch+mount+le,aps,270&sr=8-16
FireResQ282
Keith
New Jersey
Ford bronco 2021 first edition
https://www.amazon.com/Bully-Brake-Reverse-Hitch-CR-987/dp/B08LN1VQQS/ref=sr_1_16?crid=3L8TNW1RB3LOE&keywords=hitch+mount+led&qid=1675039989&sprefix=hitch+mount+le,aps,270&sr=8-16
Does anyone know which wire in a LED tailight is the backup wire to tap into?
