Dealer has a solution now for Bronco's headlight turning on/off randomly -- answer: replacement headlight switch
tongsun3717
X3
2020FordRaptor
Ty
Nevada
2020 Ford Raptor
Let's hope it does!
Jruta
Nj
A51 Bronco 2 door
Thank you! Itā€™s (so far) the ONLY issue Iā€™ve found with my 22ā€™ I knew this was a known issue but wasnā€™t sure itā€™d been resolved. I was told (over the summer) Ford would have a replacement logic board for the switch in October. That never happened lol.
Keerplunk
Izzy
Burbank CA
2007 Jeep JKU, 2022 Cyber Orange 4Dr Bronco
I bought the switch directly from a ford dealer (local dealership refused to look at the SSM 51166) instead they flashed the module. That did not work. I got the switch 4 days after I ordered it and installed it myself in all of 5 minutes, I can report it has fixed the issue!
Newbie
Miami
Sneakers
Do you have the correct part number for the switch with the fog lights button?
HRSPW
Steven
Wharton
www.hrspw.net
2022 Base Bronco, 2017 VW Tiguan
My dealer ordered the part yesterday, so it'll be in within the week, and I have it scheduled for that and the first 6-month oil change.
JT58Bronc
JT
Fl
2022 Bronco, 2021 Miata track Edition
Mine does this, they just turn on or won't turn off- and at total random times. How do you prove to the dealer that it does it and get them to order and install a new switch? It's not something that is easy to prove or demonstrate.
Brnco2.7
Dexter Michigan
1976 Bronco
Mine also does this. I took it in and it will throw out a code. Still donā€™t have it fixed Iā€™m waiting for them to get a switch. I need to do it soon because it does this at least once a day probably more that I donā€™t see.
tongsun3717
tongsun3717
X3
They can check if there is the error code.
