- Dec 30, 2022
- 24
- 381
- 803
- Salt Lake City
- 2021 Badlands Sasquatch Lux
- Badlands
I've been off-roading almost every week including mud, dust, dirt, rocky terrain, and water crossings.
I'd like to put together a detailed maintenance schedule to follow, but I'm no expert. How does this look so far? Please feel free to make suggestions - your input is welcome.
Every 5,000 miles
Every 10,000 miles
Every 30,000 miles
Every 100,000 miles
At 150,000 miles
At 200,000 miles
Power steering
The electric power steering system has diagnostic checks that continuously monitor the system. If a fault is detected, a message displays in the information display. There is no fluid reservoir to check or
fill.
Fuel filter
The Ford Bronco has a lifetime fuel filter that integrates with the fuel tank. It does not need regular maintenance or replacement.
Every 5,000 miles
- Change engine oil and oil filter
- Rotate tires
- Alignment
- Inspect:
- Automatic transmission fluid.
- Brake fluid, pads, shoes, rotors, drums, brake linings, hoses and the parking brake.
- Engine coolant system strength and hoses.
- Exhaust system and heat shields.
- Front axle and U-joints. Lubricate grease fittings if applicable.
- Half-shaft boots.
- Steering linkage, ball joints, knuckles, suspension, tire-rod ends, driveshaft and the U-joints. Lubricate any areas with grease fittings.
- Suspension, axles, shocks, control arms, springs, track bars, bushings, mounts.
- Radiator and other hoses for cracks and leaks.
- Battery – check for rust or corrosion.
- Belts, hoses, and clamps.
Every 10,000 miles
- Replace the engine air filter
- Inspect the cabin air filter
Every 30,000 miles
- Change transmission fluid
- Change differential fluid
Every 100,000 miles
- Replace the spark plugs
- Inspect the accessory drive belt(s)
At 150,000 miles
- Change:
- Automatic transmission fluid and filter.
- Front axle fluid.
- Rear axle fluid.
- Transfer case fluid.
- Replace the accessory drive belt(s).
At 200,000 miles
- Change the engine coolant
Power steering
fill.
Fuel filter
