Didn’t place order - will I be able to order later this year?
rinconryder
Wes
Santa Barbara
'16 F150
Due to a larger than expected tax bill I decided not to place my order. If I decide to place an order later this year will I still be able to do so? Thank you in advance for any input.
ilbastarge
Northeast
Tesla X
22s B&P is assumed to be in Sep-ish.
So, yes, you should be able to order later this year.
HotdogThud
mk6 gti, '21 MoarDoor
Honestly, nothing really stopping you from going in and putting in an order for what you want right now. If you find a decent dealer, they'll just put your build in at code 99 and it'll at least be in the chute and ready to go for '22
North7
North Texas
SUV
But may as well wait for the 22 B&P to see the changes.
Also @rinconryder you avoid a dealer wanting a non-refundable deposit, if you are only one bill away from not affording the Bronco you may want to save up for a couple more years.
HotdogThud
True, I thought of that after I posted. there will inevitably be some changes for '22, colors, etc. so who knows.
Either option is wide open for OP tho, I suppose.
GarageMahal
JT
Minnesota
2003 Mercury Marauder
If you haven't placed an order yet there is no way in hell you are getting one this year
I don't believe that is true. A first day reservation holder could still get a 2021 but it would not be in the first "batch" which I recall is by quarter.
Chrism81
chris
connecticut
Mazda
Is the poster a first day reservation? If so you are correct and there's a chance but if he reserved months later then he has no chance
ELKS1
Ohio
2006 F150 1977 Bronco
What exactly is code 99 I am not familiar with this?
ZackDanger
Z
Massachusetts
2021 Toyota 4Runner
Code 99 is essentially the bottom of the queue. "Hold this order at the back of the line"
When the dealer enters your order into the system, they can give it a Priority Code "99" which saves the order in the system, but tells Ford to ignore it and not build it.
At any point the dealer can go back in and change that priority code to something else, and then Ford will consider it for production.
Typically with Ford vehicles, the dealer can use priority codes to rank their orders, to give priority to "loyal customers" and stuff like that.
In the case of the Bronco, any order with any code other than 99 will be ranked by Ford according to the timestamp of when the reservation was made.
ELKS1
Ohio
I have a 7/14 reservation so I think I should be good.
