Dimensions of cargo area for 4 door hard top Badlands?
Sthomasson72
Chesapeake, VA
dimensions of cargo area for 4 door hard top Badlands
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Kind of a tricky question because it depends if you are accounting for the C-pillar/roll bar, the rear pod speakers, etc. etc.
BUT, if you just have a box that you want to put in the back of the Bronco, the maximum you can fit a box 32"x 40" x 30".
Sthomasson72
Chesapeake, VA
32” w x 40” depth”. ? Tried to look up the mat or the cargo box for the back but it doesn’t give dimensions.
but yes lookin to know how wide and deep. Thanks
RagnarKon
Bryan
New England
Those dimensions are the maximum size of a box you can fit in the Bronco.
How high do you need to go?? That's the most important dimention... because If you need to go to the ceiling then you have to worry about the rear pod speakers and your maximum width will be dramatically cut down. If you only need 1-2 feet of height, then your maximum width is much higher.
