- Aaron
- Mar 3, 2023
- 1
- 17
- 30
- Leesburg, Florida
- 2016 Ford Focus
- Black Diamond
Ok so I plan to install the following audio upgrades to my Bronco:
Kicker 47KSC404 KS Series 4" (front)
Kicker 47KSC6704 KS Series 6-3/4" (Kick Panels)
Kicker 47KSC6504 KS Series 6-1/2" (Rear with SSV Works 6.5" Pods)
Kicker Key 200.4 with PNP Harness and install kit from Hoel Wiring
So with that said, my first question is if I'm not spicing into the OEM harness for the front dash speakers do I still need to install Bass blockers? I heard that the OEM harness has them already install.
Next question, I plan to use Boom Mat on the speakers, but not sure if I need to put it on all 6 speakers, or just the rear and kick panels? Was not sure if it is worth it for the fronts.
Final question, been hearing a lot about people needed to get the ACM flash (Forscan), with the listed Amp, will this still be required? And if so does that flash have to be done after the install or can it be done at anytime?
Also just a friendly note, Crutchfield provides the Metra speaker wiring harness pig tails for free when you purchase the speakers from them, and they give you the mounting brackets too for the Kick Panel speakers. About a $40-$50 savings. Just wanted to share. Thanks in advance for any and all help.
