DO NOT BUY JBL Soundbar if you have a 2022 FIXED
22BlackDiamondGreen
Shawn
Louisville, KY
2013 Ford 150 1955 Ford F100
I had a JBL soundbar installed at my dealer in my 2022 Bronco -- when i picked it up it sounded like crap - after a week of calls the dealership was told by Ford that the software does not work on the 2022 -- after trying to call myself (transferred 7 times then hung up on) I finally used this forum to reach out -- Just got a call from ford regarding the JBL Soundbar -- They have no idea when they will be able to make it work -- I'm out over $1000 not to mention my time -- DO NOT BUY if you have a 2022
Update:
SSM 50580 - 2022 Bronco - Ford Accessory JBL® Soundbar - Programming Difficulty
Some 2022 Bronco vehicles that have added the Ford accessory JBL® soundbar may experience difficulty in programming after installation. This may be due to the Ford Diagnosis and Repair System (FDRS) function not successfully programming this accessory to the vehicle’s factory sound system. FDRS software has been updated to support a successful installation of the Ford accessory JBL® soundbar. Perform the FDRS programming function again using the installation instructions provided with the speaker on vehicles that meet this criteria.
Bronco wannabe
Bro
usa
fords
Hmmmm....maybe its 2022 only. We put it on a 2021 this week and it works great.
1979
Baltimore, MD
I wonder what’s different in the software. Also it’s super annoying that you’re out the money. I’m assuming @Ford Motor Company hasn’t offered to make it right?
RaceRedBronco
Trent
Mason Ohio
4 door Bronco Big Bend
Sorry to hear about your experience. The pricing on that JBL speaker is way to high imo. There are much better solutions out there for a lot less
22BlackDiamondGreen
22BlackDiamondGreen
Shawn
Louisville, KY
22BlackDiamondGreen
22BlackDiamondGreen
Shawn
Louisville, KY
That's who called and basically said sorry for your luck "we're working on it"
jasonf
jason
california
f150
there is more than one jbl sound bar - people just get the one thats in ford catalog that bluetooth only - on jbl website can get the better version with built in amp that a hard wire sounds much better and does not need ford dealer program .
2Jeeps&PatriotX1
Denver, CO
I’d be demanding my money back then. They can keep the product until they sort it out.
bytheway
Brice
Louisville, KY
Maybe the same reason that Forscan doesn't work on MY22s.
mdk77
BM
Illinois
Bronco Base SAS
Good to know as that was the first mod on my list. Thanks
22BlackDiamondGreen
22BlackDiamondGreen
Shawn
Louisville, KY
Just to be clear -- My dealer (Bill Collins Ford) has been great and continues to try to get the fix (that Ford has no idea when or if they'll figure out)
Blitzjb
Joel
Long Island
2021 Ford Bronco OBX
It is a defective product- have then remove and refund your money - if thy can not fix it after 3 tries - tell them it is now a lemon...
da_jokker
Jeep Wrangler JKUR
I can't see how this would work because the head unit is the one filtering the signal. The reprogramming is what opens that up.... Unless that's the change? I wonder if 2022 they removed that stupid rear limitation?
flip
Phil
IN
www.ruxerparts.com
Fords
I've got our FAD rep contacting JBL for help but presume this is a FDRS issue and software hasn't been released yet but assume it's in the works.
wordstew
Mass
H3 Hummer, Explorer Sport, BMW R1200C
Skip the soundbar and get yourself a Mackie Freeplay for around 250 bucks.
Throw it in back seat and you're all done.
Portable and multiple uses... now you can even have yourself some car/campsite Karaoke, or a PA to run your guitar/voice through or play some mating calls to attract in wildlife or a potential mate
This thing is very loud and like an old school boombox keeping in in the retro style of the Bronco
you could have 4 of these (300 watts each & 8 inch woofers) for the cost of 1 soundbar and that would blow the roof off...
https://www.walmart.com/ip/Mackie-F...o-4-Channel-Mixer-Personal-PA-System/48570028
Ford Bronco DO NOT BUY JBL Soundbar if you have a 2022  FIXED 1644682030420
Ford Bronco DO NOT BUY JBL Soundbar if you have a 2022  FIXED 1644682071740
