- Raymond
- Jul 29, 2020
- 29
- 977
- 1,307
- Florida and Virginia
- F-350, F-450, 2022 Bronco, (2) 77 Broncos
- Badlands
This just happened to me recently.
The Driver's side window will go all the way up and stay up, but not with a 1-touch. However, When you open the door it does not go slightly down and then back up when you close the door. The window does not seal automatically.
Once inside with door closed, I can lower the window slightly and then raise and the window does seal correctly. It does not seam like the window itself needs adjustment.
Is there a Sensor that has gone bad?
Any others like this?
What's the solution?
