(ENDED) 🔥 Exclusive Groupbuy: Bronco Triple LED Fog Light Kit for Steel Bumper
Fencelizard
Bronco Sasquatch 2.7
Designed and assembled in USA but where are the components made?
Timothy
Omaha
2020 Rogue / 2019 4Runner / 2010 370Z
OP: If I have factory fog lights and I swap to the steel bumper, would these lights work by directly connecting to the harness from the factory fog light and subsequently function with the factory designated button?
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
These use Cree XR_E LEDs which is a US manufacturer, the moldings, PCB, etc are assembled overseas. We do what we can to source US components and keep pricing and availability in line with what our customers want. (y)
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Yes, your scenario is probably the easiest installation since you already have cable leads right there. You can just connect the wiring to your existing fog light cables and use the factory switch to turn them on and off.
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Only a couple more days to get on this Groupbuy! Based on demand we anticipate completely selling out of our initial production so don't miss out.
mykoljay
North NJ
2021 Bronco 2DR
Ordered!
4% cash back from rakuten
OtisFE
Otis
Alexandria, VA
2022 Bronco OBX
Any update on anticipated ship date?
cmlcpt
Buzzards Bay
2021 Outer Banks
Do you have instructions for dummies on how to install to aux switch?
Cfield90
South FL
21 Bronco/22 Escape/01 Softail/90 Bronco (former)
You tube.
Black wire to any ground (there are several - look for black wires coming from negative battery cable) and connect red to whatever aux switch that is rated for amp draw. I think I am going with #1 for the triple fogs, but not sure, as I haven’t looked at amp draw yet. You just need to make sure you match the correct color coded aux wire — they are taped together near driver bulkhead.
Zoomer6
Dallas
Kia Sorento
Ordered! Now if I can just get my Bronco to install it on.
OracleLights
OracleLights
New Orleans, LA
www.oraclelights.com
F OR D
BD Green Machine
Alright, I will order the amber IF
TWO PEOPLE RESPOND AND WANT TO TRADE ME WHITE ONES.
In PA but shipping should be easy via priority 3-day.
To clarify, two people send a pair of white lights, I will send each person a pair of amber. I am looking to do the amber/white/white setup.
lsirois
Luc
NH
2015 Ford F-150 Supercrew Lariat
I want the same and will swap a pair of whites for a pair of yellows with you.
