Everglades front camera
BK1
SC
C8, GMC At4, BMW
Just got everglades and want to know if anyone knows what is involved to get a front camera? Ford performance shows a winch on bronco w a relocated camera mount. Can this be added to Everglades? Is wiring already there? Can camera button switch be added? Electronics flashed? Please let me know if you have gone down this road and what all is involved. Thanks
The cheapest way to add a front camera is just get a cheap backup camera, and mount it up front. $30 from Amazon gets you a camera and a 5” screen that works well enough.
If you want an OEM finish though, there are options. Naviks comes to mind, but there may be others. This thread has more detail. It costs an order of magnitude more though.
https://www.bronco6g.com/forum/threads/adding-front-camera-to-base-bronco.33648/page-2
The relocation kits really only are for folks that have the 360 camera system with OEM cameras. If you don’t have that from the factory, you don’t have the mounts or wiring for the camera and have to find/make a mounting point all on your own anyway. I suppose you could use one of the relocation brackets as a starting point to mount a new camera though.
HolidayDog
Everglades
MT
24 Everglades
Everglades
Watching. đź‘€
Very much interested in this project.
BlueBronco
DFW
Easiest way to check if the wiring is there is to open your hood. My camera has a disconnect for the wiring and washer nozzle atop the grill by the air box intake.
As far as getting the camera to work, I am not sure if there are modules needed or if it is just a matter of making some changes with FORScan.
Rydfree
Benny
Alabama
Copperhorse73
Justin
Mooresville, NC
2022 4 door Wildtrak, 2024 2 door BB Sasquatch
Probably won't get any easier than that kit . Looks like you have to switch video sources from a remote but then you can input other video onto the factory screen also if you wanted to .
Yeah, that’s my take as well. Considering what’s probably missing from the 12” non high package setups, I figure this would be a best case compromise. If I had an Everglades or one of the lower trim 2024 models, I’d give this a shot. Having that front camera on the trails was literally the only reason I wanted high package to begin with.
