Slyder
Washington
2014 KTM 1290R
Same weight as the original Sasquatch tires?
Ford Performance lists the whole package as weighing 205 lbs.
If you divide that by 5 it comes out to 41lbs per wheel. So it's safe to say they weigh pretty much the same as standard Sasquatch wheels.
LethalPerformance
Jared
South Florida
www.lethalperformance.com
stonerdoom
chicago
2004 Ford Explorer Sport Trac
They’re the same size/offset. Just a different design.
The only real upsize with the stock Sas wheels is they are beadlock capable, which means you can install real beadlock rings onto them (also available at @LethalPerformance here). The Everglades wheel is not beadlock capable.
A couple of questions, if you would be so kind...
These are a perfect swap in terms of poke and tire fitment? Meaning if I was so inclined, I could get these and put the SAS tires on them and then only difference would be the style appearance on the SAS Bronco I hope to get (900 days and counting)?
Last, would something like this be available to use those FORD points everyone is always talking about? Might help offset the cost as there is literally nothing else I would see myself using those points on.
LethalPerformance
Jared
South Florida
A formal ad, why not!
peterh
ny
jeep wrangler jlu 2018
okay its a step in the right direstion - still holding out hope that someone will produce slot styled wheels in polished or bright silver with high positive offset - i know they wont have deep concave design but these everglades wheels show that its possible to create a slot style in oem offset and make it look cool
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
Yes, they’re the same size.
Stock Sasquatch wheels are 17x8.5 +30. The Everglades wheels are also 17x8.5 +30.
In case you aren’t familiar with wheel sizing…. DDxWW +\-OO:
  • D = diameter in inches
  • W = width of rim in inches
  • O = offset, usually expressed in millimeters
Unfortunately you can’t use FordPass points for them. As @LethalPerformance said, Ford Performance is a separate entity, so different rules. Some dealers will let you use FordPass points if you purchase through the dealers, but Ford Performance doesn’t flow through the same part wholesalers that “normal” parts do, so you are unlikely to get a decent price through your dealer.
The Ford Performance ProCal tuner, for example… I got that from @LethalPerformance for $600-ish. Same exact part through my dealer would have cost around $908.
Keep in mind there are several Ford Performance distributors out there, so feel free shop around. Just so happens my favorite is @LethalPerformance. (Not sponsored in any way… but if you wanted to sponsor me… I do like these wheels ;) Just sayin’.)
LethalPerformance
Jared
South Florida
When are they going to sell the snorkel kit?
Ford Performance ->
Due to the complexity of offering a bolt-on one (i.e. having to offer the everglades fender as well or requiring extensive modifications), there is no current plan in offering one. They're looking for work-arounds in the future.
tractorcrusher
Curtis
DFW, TX
Ford Performance ->
Come on Ford... I have a sawzall, duct tape, and zip ties.... think like a tuner.
LethalPerformance
Jared
South Florida
Haha I can see what the actual OEM replacement parts would cost if you'd like.
SilverSurfer
Danville, Ca
Black Diamond 4dr MIC
Any idea how these would work on BD with 33" tires? I assume different offset is only issue?
Lowcountry Bronco
Lowcountry Bronco
William
South Carolina Lowcountry
BD is 17x7.5 55 offset but don't see any reason why it wouldn't work. Plenty here have mounted Badland and Sasquatch wheels with no issue so I'd follow whatever guidance for that (crashbar removal?).
gringoloco
Germany
2023 2-Door
gringoloco
Germany
2023 2-Door
Are these wheels cast or forged?
DrewMackin
Drew
Dripping Springs, TX
23 Tesla Model 3, 23 Bronco Heritage
Best looking OEM wheels for the Bronco! but I may be biased. Look good in real life, color works well with all MIC plastic bits everywhere and especially if you have the dark grey grill. I'd buy them ASAP if I hadn't switched my BD to the Everglades.
