I have a 2022 2dr Badlands Sasquatch and am thinking of running 37s, how much lift do I need? How would switching out the wheels to something with zero offset change the amount of left needed?
By all accounts for a 12.5" (or less) wide tire...2" to 2.5" of lift on a 0mm to +18mm offset wheel. IMO proper lift over 2" would include coil overs, new UCAs and adjustable rear track bar. Would also be prudent to install steering rack bushings and upgrade/brace tie rods.I have a 2022 2dr Badlands Sasquatch and am thinking of running 37s, how much lift do I need? How would switching out the wheels to something with zero offset change the amount of left needed? View attachment 526604
When you say âhow much lift do I needâ ⊠to do what? ⊠a lift just to eliminate most rubbing driving to work, or actually a functional lift for wheeling?I have a 2022 2dr Badlands Sasquatch and am thinking of running 37s, how much lift do I need? How would switching out the wheels to something with zero offset change the amount of left needed? View attachment 526604
Ah, yes, I guess that needs some qualification. I want to lift it so that I can run 37s and also retain, if not improve on, all the Bronco's current capabilities.When you say âhow much lift do I needâ ⊠to do what? ⊠a lift just to eliminate most rubbing driving to work, or actually a functional lift for wheeling?
Even with a 3â lift in front youâll have to address rubbing. If youâre just getting 37s for looks, get some perches, run BFG K02s ( shortest 37) , and stick with a positive offset wheel. Otherwise search the forums, there are many posts of what Coilover/UCA options there are, and what you will need to do to address rubbing with 37s.
Then plan to spend some money on suspension !! And do some cuttingAh, yes, I guess that needs some qualification. I want to lift it so that I can run 37s and also retain, if not improve on, all the Bronco's current capabilities.
Thanks, but I was looking for something more helpful.Then plan to spend some money on suspension !! And do some cutting
I believe he was referring to something like the big tire clearance kit.Thanks, but I was looking for something more helpful.
Right, I've been looking into a big tire clearance kit. Sounds like a good idea.I believe he was referring to something like the big tire clearance kit.
Cut crash bar brackets
I'm no expert on any of this stuffRight, I've been looking into a big tire clearance kit. Sounds like a good idea.
Ohhh ⊠then here is MY summary answer to your question, itâs what I have. You can certainly go with less expensive pieces parts. Short answer is a âliftâ and wheel choice isnât all that you will need to run 37s if you want it really functional off road.Thanks, but I was looking for something more helpful.
It depends on the Tires. I run Maxxix RAZR At 37s which run Smaller like BFGs. I love these tires and have done a fair amount of off road also. I would stick to these 2 tires, the More "true " to 37s will be more of an issue, plus tires with large side lugs like a mud tire could rub more. Stock rims or close to stock offset i believe is best, "0" offset or Negative , moves the "sweep" of the tire out and will cause more spots to possible rub.I have a 2022 2dr Badlands Sasquatch and am thinking of running 37s, how much lift do I need? How would switching out the wheels to something with zero offset change the amount of left needed? View attachment 526604
Good stuff. How do you like those Fox Shocks and the Camburgs? As to the lift height, I was hopping to get away with 2 inches, as my garage door is a limiting factor, unless I was to remove the roof rack, which is a possibility.Ohhh ⊠then here is MY summary answer to your question, itâs what I have. You can certainly go with less expensive pieces parts. Short answer is a âliftâ and wheel choice isnât all that you will need to run 37s if you want it really functional off road.
Fox 2.5 coilovers, Camburg UCAs and Camburg trailing arms. Keep in mind anything over 3.5 lift in the front and youre asking for certain tie rod and CV joint issues if you really flex your truck. Pick a tire and pick a wheel ⊠keep the wheel 0 offset or positive, doesnât really matter with 37s, it will rub anyway. Plan to do some cutting in the front and the back if you are actually going to flex your truck ⊠search for my thread on that, itâs all there. Get a tail gate brace for the heavy 37 hanging off the back so it doesnât buckle when youâre hauling ass. Youâll be into it over 10k at this point .. thatâs IF you do it all yourself ⊠and then if youâre actually serious about crawling youâll start upgrading your steering. Thatâs a totally different subject lol.
And like I said before, there is a ton of information that you can search for on the forums on this subject that will answer every question you could possibly have ⊠if you look ! Also ⊠disregard the posts that claim theyâre running 37s with no rubbing without doing some cutting lol
There, thatâs my recommendation for a lift etc for 37s that is functional for what the Bronco was designed to do. Was that helpful ? ⊠good luck!
Do you (or anyone out there) know whether the Max tire kit voids the warranty?I believe he was referring to something like the big tire clearance kit.
