- Ezra
- Mar 6, 2021
- 9
- 125
- 771
- Columbus, Ohio
- 2021 White Ford Bronco (moar door, 7spd, lux)
- Badlands
I thought of you @KRoyal080 …
A month ago I installed some rear-facing rally lights from F150LEDs, and enjoyed a day-long project of snaking wiring along the frame and hooking everything up just right.
A few times, the lights wouldn’t activate when I flipped Aux #6 and today I decided to investigate. It occurred to me that maybe heat under the hood had something to do with it.
With the engine running and switch #6 flipped on, I saw no lights so I popped open the hood.
The wires from the relay to the upfitter wire splice were WHITE HOT. I could barely hold them without burning my fingers! Had they been bare wires, they would have been glowing red. A minuscule puff of smoke emerged from the area near the splice. I quickly shut off both the switch and the engine, and the wires got hotter. I pulled out the inline fuse to eliminate current and turned around to search for some wire cutters when I heard a pop!
Alrhough there were no flames, billowing white smoke bellowed away from the wire bundle as both the insulation and the sheathing burst open. I was ready to run for the nearest fire extinguisher when I proceeded to clip the wires, cutting their connection to the battery (and hopefully the source for combustible energy).
I suspect there was a short in the harness I was provided. Although I’m an amateur electrician, all of my connections were installed correctly, and this case is beyond my ability to diagnose. I would have thought a fuse would have blown further upstream rather than cause a near fire.
Thank the Lord! I don’t want to imagine had it not occurred to me to pop the hood and troubleshoot things this afternoon…My Bronco was already in the garage and my family is home.
Below you can see the vendor-supplied splice connection and the quarter-inch length of Upfitter #6 cable I sacrificed to disconnect this firetrap.
