FIRST LOOK: Flush Style LED Tail Lights for the 2021+ Ford Bronco from ORACLE Lighting
Beach_Bum
Ken
St. Augustine, FL
Eric L
2020 Explorer ST, 2017 Fusion Sport
ORACLE Lighting
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Hey I just installed the flush mounts and made the forscan changes and now I have a bunch of DTCs related to the Body Control Module. I double checked the changes and they are accurate. Any experience with this or suggestions?
That's really odd, you may want to reload the as-built and then try making the changes again. We have done this dozens of times without any DTCs.
Eric L
It sounds like it's the tire size change I did at the same time. I was able to clear the other DTCs except the ones related to the tire size
ORACLE Lighting
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Yep, didn't see someone already answered. Glad to hear you got it worked out!
ORACLE Lighting
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Check out the ORACLE Flush Mount Tail Lights installed on the Imagine Dragons Bronco as seen at the SEMA show!
Unveiled for the world to see at SEMA 2023, Galpin Auto Sports’ Ford Bronco is a one-of-a-kind off-roader that captures the essence of both the Bronco’s heritage and the musical magic of Imagine Dragons. The collaboration between GAS and the band resulted in a remarkable vehicle that seamlessly marries the world of music and automotive artistry.
The Imagine Dragons-inspired Bronco is based on the rugged Badlands four-door model. What sets it apart is its unique and nostalgic styling. The design team at GAS drew inspiration from the older Broncos, giving this modern off-roader a retro touch. At the front, you’ll find a Ranger-style grille and badging, paying homage to the Bronco’s heritage. The standard wheels have been swapped for custom aluminum wheels from Fifteen52, finished in a striking gold color that complements the Eruption Green metallic paintwork. These wheels are wrapped in rugged 37-inch Toyo Open Country M/T tires, ensuring this Bronco is ready to conquer any terrain.
The gold accents extend to the detachable roof and the grille, creating a harmonious contrast with the vibrant Eruption Green. The vehicle not only boasts stunning looks but also impressive off-road capabilities. To enhance its performance in challenging terrains, GAS has equipped the Bronco with a 2.5-inch Camburg suspension lift kit and Bilstein shocks. These modifications make it clear that this Bronco is not just a showpiece; it’s a true off-road warrior.
As seen at the SEMA Show in the Grand Hall:
Ford Bronco FIRST LOOK: Flush Style LED Tail Lights for the 2021+ Ford Bronco from ORACLE Lighting IMG_5398
Ford Bronco FIRST LOOK: Flush Style LED Tail Lights for the 2021+ Ford Bronco from ORACLE Lighting IMG_5396
ORACLE Terry
Terry
New Orleans, LA
Bronco, RAM TRX, Gladiator, Wrangler JL,
Tomleo67
Tom
Mass
22' big bend 4 door
dam I was planning on doing the black rear led flush mounts but didn't realize I would have to use forscan (n)
ORACLE Lighting
ORACLE Lighting
ORACLE
New Orleans, LA
oraclelights.com
Hello @Tomleo67 You do not need to use Forscan, do you have base or LED tail lights?
