Forscan changes to activate 25+ trailer module?
kcmusa
kc
Georgia
2025 bronco bablands
Thanks. So my understanding is I make no change to the TRM settings listed. Just there for info..
RoverDude
Maryland
2021 Bronco (First Edition)
If they're different than what you have, yes you should change them.
Pedey321
2025 Big Bend w/ Black Diamond Pkg
RoverDude,
I believe you're saying to change only the specific alpha-neumeric characters in the spreadsheet you show in given columns for various modules (besides the TRM which start with 791-...). The TRM (791-... ) characters should show exactly as shown in spreadsheet).
In the other modules (e.g. IPCM starting with 720-..., if vehicle has them, the xxx's are not to be changed because they are specific to the individual VIN due the various trims, packages, options, etc. (i.e. they're vehicle specific and not tow module related).
From what I found regarding ford's part identificationS2e.g. S2DT-19H378-BA.
S2DT specifies the year and model of the applicable vehicle.
19H378 is the base engineering part number for module trailer brake, in this case.
B is the variant, for example could represent left hand or right hand drive.
A, at the very end, is the release or revision identifier (letter).
If there's a revision to BA, then the new suffix will be BB, then BC, and so forth.
Parts with later revisions should work / fit for previous (superceded parts).
Happy, safe, enjoyable Thanksgiving to all.
RoverDude
Maryland
RoverDude,
S2DT-19H378-BA is correct for MY 2025+( not for years prior)
ReactiveD
Derek
Citrus County, Florida
2025 Bronco OBX, 2024 F150 Platinum, 2015 Mustang GT
See below for 2025 setting.
The TRM is much larger (more lines/ different, it a diffrent firmware module for 2025+)
also The ipc is slightly different
720-03-02 requires (2) changes
These are what I gave EastALHijet, and they confirmed it worked (for them)
as always:
back your own setting beforehand, and use at your own risk
Let me know if you have any issues
Instrument Panel Control Module720-03-02xx4xxx--Trailer Sway0=Disabled4=Enabled
Instrument Panel Control Module720-03-02xxxxx1--additional value for (1) is part of 2025 version for trailer Lighting
Instrument Panel Control Module720-07-01xxxxxCxxxx--Trailer Brake Controller4=TBC DisabledC=TBC Enabled
Body Control Module726-01-02xxx1xxxxxx--Trailer Connect Config0=Disabled1=Enabled
Body Control Module726-40-01xxxxx1xxxx--Trailer Outage Config0=Disabled1=Enabled
Body Control Module726-69-02xxxxxxxxx1--TRM Installed / Config0=Disabled1=Enabled
Parking Aid Module736-01-01xx8xxxxxxx--Pam Config0=No Trailer Module8=Trailer Module
TRM Trailer Module (TRM)791-01-019000000091BB
TRM Trailer Module (TRM)791-01-02070A000000AC
TRM Trailer Module (TRM)791-01-03000006A2
TRM Trailer Module (TRM)791-02-01A301004B4BD5
TRM Trailer Module (TRM)791-02-024B4B4B00007D
TRM Trailer Module (TRM)791-02-0300FA001900B0
TRM Trailer Module (TRM)791-02-040500320005DA
TRM Trailer Module (TRM)791-02-0500000A0003AC
TRM Trailer Module (TRM)791-02-06001E000E07D3
TRM Trailer Module (TRM)791-02-07D00000000071
TRM Trailer Module (TRM)791-02-080000000000A2
TRM Trailer Module (TRM)791-02-09000000A3
TRM Trailer Module (TRM)791-03-01D00064640034
TRM Trailer Module (TRM)791-03-0200009D
TRM Trailer Module (TRM)791-04-01000000FA0097
TRM Trailer Module (TRM)791-04-02FA00FA00FA8C
TRM Trailer Module (TRM)791-04-0300000000009F
TRM Trailer Module (TRM)791-04-04000000A0
TRM Trailer Module (TRM)791-05-0100000000009E
TRM Trailer Module (TRM)791-06-01FFFCFFFCFF94
TRM Trailer Module (TRM)791-06-02F33FFCFFFFCC
TRM Trailer Module (TRM)791-06-03FF007BFF3C56
TRM Trailer Module (TRM)791-06-048022
TRM Trailer Module (TRM)791-07-0103EA051404AA
TRM Trailer Module (TRM)791-07-024B0565010057
TRM Trailer Module (TRM)791-07-030100010001A5
TRM Trailer Module (TRM)791-07-040001000004A8
TRM Trailer Module (TRM)791-07-050005000400AD
TRM Trailer Module (TRM)791-07-065C0075005CD2
TRM Trailer Module (TRM)791-07-0705DC04C30654
TRM Trailer Module (TRM)791-07-088A0000000031
TRM Trailer Module (TRM)791-07-090000A8
Side Object Detection Left7C4-01-01Bxxx--Left BLIS3=Auto / No Trailer
B = Auto /Trailer
7=Manual / No Trailer
F=Manual / Trailer
Side Object Detection Right7C6-01-01Bxxx--Right BLIS3=Auto / No Trailer
B = Auto /Trailer
F=Manual / Trailer
Accessory Protocol Interface Module7D0-01-03xxxxxxx4 xx--Trailer Setup Configuration0=Disabled4=Enabled
Accessory Protocol Interface Module7D0-01-04xxx6xxxxxx--4 Pin/7 Pin Connector2=No Connector6=Connector
Accessory Protocol Interface Module7D0-09-02Cxxxxxxxxx--Trailer Sway4 =DisabledC=Enabled
Will this be the same on a 2025 Outer Banks with 314A package?
BuildB6
Gene
Kansas City
2025 Bronco
I just wanted to say thank you to RoverDude.
Just installed hitch and module on my 2025 and changed all these settings with ForScan and all seems to work with no codes. Great job!
RoverDude
Maryland
Awesome sauce!
Just an FYI to anyone reading this in the future
Reminder. The common trailer light tester (on Amazon.) that has a single LED for each pin/light group NOT be seen by the bronco's system (it won't say "trailer connected" on the dash. when you plug in the tester).
Those testers do not have enough load typically to be seen.
SlowTrak
NorCal
It's an SUV btw....
Awesome sauce!
Do you know of one that tricks the bronco into thinking a trailer is attached? I did buy one of those 4 pin/7 pin combo testers and it doesn't seem to trick the bronco. I can't get the Trailer Light Check functions to work through the app or the screen. When I manually trigger the turn signals, the lights are working though.
Pedey321
There is a distinction relative to which version / type of lights you have / are testing and with which specific tester. Certain 6G models / trim packages (& MYrs) come stock with either LED or halogen bulbs. I have a '25 Big Bend with Black Diamond package which came with halogen break / tail lights and I got the Amazon 'NeaLia 7 Pin Trailer Plug Tester, 7 Way Wiring Tester for RV, ... Connector' to work fine on mine. I tow a boat (<3,000#s) and also use our RV to flat tow our Bronco with no problems.
After using / following Rover Dude's help & some experimentation, I have the ability to test the trailer's lights without leaving the driver's seat.
Regarding which lights you may have, check out related threads like https://www.bronco6g.com/forum/threads/from-halogen-to-led-all-taillights-replacement-options.89978/.
One word of caution to all who've gone the DIY tow package is to make sure you tell the mechanics (Ford / other) that you have the TRM installed and configured. I took mine in for a recall and the tech apparently reloaded the stock as-built from Ford - removing the TR Module from display panel / settings / functionality. I checked before leaving and had them reload which they didn't fully restore the full TRM related menu. Apparently Ford does not update their as-built database to reflect that a TRM has been added.
Good luck / happy / safe 2026.
Ted Miller
Ted
Phoenix, AZ
2025 Bronco Outer Banks
Just got back to this. I started from scratch and followed these instructions again, but it still leaves this DTC code that I cannot reset. As indicated, when I start the car the check-engine light does NOT come on (“Malfunction Indicator Lamp is Off for this DTC”). But I’ve tried to reset it and re-read DTS and it’s still there:
Code: U0137 - Lost Communication With Trailer Brake Control Module
Status (-0A):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Instrument Panel Control Module
Maybe it’s not important…?
Did you ever figure out how to clear this DTC code? I just installed my trailer module and configured everything with Forscan according to this thread. Everything is working except I'm getting this same DTC error code (Code: U0137 - Lost Communication With Trailer Brake Control Module).
BuildB6
Gene
Kansas City
2025 Bronco
The tow module, trm (trailer relay module)
Fords own description, a referencing the same thing.
The Lost communication could or might be simply when you programmed the module, and it reboots. Because for a few milliseconds it does lose communication if it's system talking to it.
When I installed mine I disabled trailer brake controller in the IPC module, because I have no controller. No errors
Ted Miller
Ted
Phoenix, AZ
That worked, no more DTC codes! Thanks for the quick reply!
SlowTrak
NorCal
It's an SUV btw....
So I have the signatures from the factory. How does this play into if these testers should work from the app and the screen?
Was the recall for the rear camera? If it is electronics related I can see them reflashing the as built data I suppose. Good to know and a good reason why you should save your changed settings. Would make reflashing the reflash easier haha.
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
Is it just one line to change in order to enable the Trailer brake module on the 2025? I have tow module activated by dealership.
Ted Miller
Ted
Phoenix, AZ
Yep, just this line needs to be changed.
