- Thread starter
- #16
Can you show how rears attach to bumper? Bumper had receiving holes or?Absolutely love mine.
Never mind…I just watched video of how to and you drill holes into bumper plastic. I plan to have ARB rear bumper so unsure at the moment how I will accomplish thisCan you show how rears attach to bumper? Bumper had receiving holes or?
The video on the website is great and shows step by step how easy it isHave fronts only. No logos.
Great fit, nicely engineered of quality materials.
My only caution is the printed instructions would tend to prompt one to install backwards - let’s me careful out there.
Will these work on a non-Sasquatch Black Diamond? ThanksI bought the $581 unbranded set and I think they look alright. Sure, the Bronco doesn't look as good as with no mudflaps, but now I don't have to worry so much about rocks hitting my doors or someone driving behind me.
The install instructions suggest taking the wheels off. I don't have a good way to do that so I didn't, and it turned out fine. It was more annoying to install but not impossible. I bought the version that goes with rock rails and the cutout is pretty accurate. It held me back from getting the mudflaps exactly where I wanted them, but they still mounted straight.
One nice thing about them is all the metal components - bolts, nuts, washers, maybe the brackets too - are stainless steel. And the bottom rubber half is removable.
Is there a model for Sasquatch and then also a different model for non-Sasquatch? ThanksAbsolutely love mine.
I believe they will work fine. The instructions say "Not recommended for base models with 30" tires". They will probably hang really low to the ground on 32s. There is a slight alteration to the install if you have crash bars or not, but it's otherwise identical.Will these work on a non-Sasquatch Black Diamond? Thanks
No. There is a different model if the Bronco has the factory rock rails or not, but other than that it is the same.Is there a model for Sasquatch and then also a different model for non-Sasquatch? Thanks
Thanks. I know about the rock rail one's and their are 3 logo/no logo designs too. I am putting larger wheels and tires on mine so I think these will work great. I was just not sure about the rear mounting to the bumper as mine will not have the extra flair out on the fender as the Sasquatch pkg does. Thanks again.No. There is a different model if the Bronco has the factory rock rails or not, but other than that it is the same.
….and they look great!! With the horse is spendy but sure looks coolThey've been great !
Block the rocks fantasticly.
