- Thread starter
- #136
I am not versed on the electronics of the Bronco, but when I read the description on their website, to me this is indicative of being able to tie into the circuit so that when your door opens or you unlock the Bronco, this light is activated like the existing ones. @GoatFab any chance you can shed additional clarification as to if that is possible?
The idea behind the light was to offer something that fits the masses. Tying in the light to the door system or the turning on of the factory light would enable you to also turn on this light. My thought or preference was to tie into an upfitter switch to use mostly when off road and toggle between the white and red light. Again, this is how I intended personally to use mine.
There are a ton of inexpensive LED light options available should you just want to have a dome light that then would be connected to automatically turn on when the doors are open. (no switch)
Most of these LED dome lights can be found for around $10 should this be the desired use of a light.
Again, I was trying to supply something that was more offroad focused.
Adam
