Trying to decide for mine would sask with -12 offset have any Polk?I think mudflaps (I installed RokBloks) will cut down some spray up the side. But even with SAS flares you’ll still have poke and top of tire spray at -18 offset.![]()
Thinking you would still have some poke.... from what I can tell/measure, my tires are sticking out ~6" from body, and 3" from outer fender... The Sasflares should get you an extra ~1" from the body, and the reduced offset would get you another .~25" closer ..... Depending on the tread of the tire could potentially minimize look even further. ... I think, -12MM with a sas size flare would probably be ideal set up... I was just so hung up on these Fuel Milititas and wanted 20X10, my only options were -18 or 0 to positive offset......Trying to decide for mine would sask with -12 offset have any Polk?
Thank you!Thinking you would still have some poke.... from what I can tell/measure, my tires are sticking out ~6" from body, and 3" from outer fender... The Sasflares should get you an extra ~1" from the body, and the reduced offset would get you another .~25" closer ..... Depending on the tread of the tire could potentially minimize look even further. ... I think, -12MM with a sas size flare would probably be ideal set up... I was just so hung up on these Fuel Milititas and wanted 20X10, my only options were -18 or 0 to positive offset......
Removed the Grill, flipped over, and used a 1/4" drill bit to drill through the plastic ... follwed this video : (62) 2021 Bronco Black Diamond Color Matching Grill Letters - YouTubeTruck looks great.... how did you remove the white letters?
Thank you....was hoping it would be less effort.... maybe just use a v small paint brush? Appreciate your reply and will send image when I color mine.Removed the Grill, flipped over, and used a 1/4" drill bit to drill through the plastic ... follwed this video : (62) 2021 Bronco Black Diamond Color Matching Grill Letters - YouTube
Yep.Trying to decide for mine would sask with -12 offset have any Polk?
Looks great!Came from dealer with 2.5” 4wp level kit and modified crash bars
So far :
Tinted windows
Removed white Grill letters
Center Grab handle delete
Stubby antenna
20” Fuel Militias 20x10, -18mm w 35/12.5/20 ridge grapplers
Fusion Plus Xpel Ceramic
Replaced factory speakers with Focal ACX Kicker Key 200.4 , Kicker 500.1 to Kicker 8” down fire
Sounds awesome to me , 0 rattle
Marine vinyl wrapped cheap cargo shelf (hope some rain /theft protection for sub)
I’ll probably eventually color match /paint the bumpers gray . But other than that , I think I’m done with this thing for a bit.
Thanks to the contributions from this forum and those that paved the way to make it easier for the rest of us
At first I wasn’t a fan of the 2 tone Roast leather and thought about swapping interior , painting dash to remove brown…. but it’s growing on me.
Can you elaborate on your speakers? Did you do component speakers in the front? What subwoofer are you running? 2-OHM? Is the subwoofer mounted? Where did you mount the Key 500.1? Stereo is next on my list.Came from dealer with 2.5” 4wp level kit and modified crash bars
So far :
Tinted windows
Stubby antenna
We have very similar Broncos. I have a Carbonized Gray OuterBanks on Fuel Rebel Bronze 17 with 37x12.5 KO2. I just did the Black Letters and upgraded the front fog lights with Diode Dynamics Elite.
Damn them 37s are beast!!! I dig the bronze fuels with the gray, looks great !!Can you elaborate on your speakers? Did you do component speakers in the front? What subwoofer are you running? 2-OHM? Is the subwoofer mounted? Where did you mount the Key 500.1? Stereo is next on my list.
i considered the tailgate as well. I think it is probably the coolest looking, but also thought about the extra weight. In addition risk of being damaged by stuff in the back and exposure to rain when I get caught with rear windows removed &/or top down .Yeah, my wife wanted the 37s. I was worried about the performance with the 4.27 final drive and the 2.3 engine but I am happy with the result. The Bronco moves.
I was thinking of doing one of these MTI Acoustic Enclosures but you may have convinced me to do Kicker Down-firing sub and save the money plus I am worried that the sub will overload the tailgate since I didn't add the tailgate reinforcement when I added the 37 to the tailgate.
Anyway, here is one more mod you might be interested in. I did the blackout Ford Emblem, I found it on Etsy.
Awesome thank you!Here you go: https://www.etsy.com/listing/1026555220/
Comes with a plastic tool to remove the existing one.
