Has BL always been 4.7 rear axle
Razorback
Bill
Dallas
Lincoln MKX
I thought Sasquatch was the only way to get the 4.7 rear axle...I remember having to select it and then it was announced you couldn't add it a la carte. But it shows 4.7 as regular BL. I know I've begun to forget things, but now I must be remembering things wrong also.
AcesandEights
Ace!
Oregon
DR650
Yep, manual trans BL gets 4.7.
Razorback
Razorback
Bill
Dallas
Lincoln MKX
With the 7 speed it is. Automatic gets 4.46 or what ever it is cause I'm to lazy to look it up.
Thanks. Thought I was going crazy. I didn't switch the 2.7l and automatic running through the options again...
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Yep, when the MPG numbers where released I totally forgot the manual got the 4.7 and thought why does the 2.3l get such shitty mileage compared to the 2.7l in the Badlands all things equal. Then I remembered they weren't equal and the rear end ratios are different.
Drex
Jake
The info is all correct in the posts above, just a clarification; All Bandlands come standard with 4.70 gears.
You can get the optional automatic transmission and gear package (4.46 which is 5% less steep gears), if you get SQ'd, you get to keep the standard 4.70 gears with the auto. People keep swapping what is optional and what is standard on the gearing
