How long to install light bar, ditch lights, and fog lights?
BroncoTrail
Salt Lake City
2021 Badlands Sasquatch Lux
I have a 40" light bar, a pair of ditch lights, and three pairs of fog lights that I'd like to have installed. I got an estimate from a local shop on how many hours it'd take for them to install them for me but it sounds a bit high. What's the average time for a job like this?
toughtoaster
Kansas City
2012 Mustang GT, 2022 Bronco Badlands
There’s a few key factors missing to give a best case estimate. Do all of these have all necessary hardware and wires? Are you wiring to the aux switches? Mounting locations for each of these?
Offhand without knowing the above I would say maybe 4-6 hours though with 1 guy.
1979
Baltimore, MD
How many hours did they quote you? That’s quite a bit of work. Also need answers to all the questions above.
BroncoTrail
BroncoTrail
Salt Lake City
I have everything needed to get the job done including mounts, wires, etc.
The fogs, pods, and light bar will be connected to three separate aux switches.
The light bar will obviously be mounted on the roof - I have the mounting hardware for it. The ditch lights will be mounted in the usual location. The three pairs of fog lights will be mounted in the stock Bronco bumper.
They quoted me 9-12 hours. I feel like that's high.
toughtoaster
Kansas City
I wouldn’t think it takes more than 8 hours. Any reason you don’t DIY? It’s not terribly difficult except for the scary part of drilling a hole in your windshield header for the light bar wire to pass through.
BroncoTrail
BroncoTrail
Salt Lake City
I don't have a driveway/garage to do the work in.
Also I thought that the Bronco has a pre-made channel for the wiring. It explains it in this video.
MillerAndCheeto
Robin
Calgary, AB
2 Door Cyber Orange Wildtrak Sasquatch
Including opening the boxes, assembling lights, hooking up harnesses and mounts and routing cables, the Baja XL80 A pillar lights took me roughly 1 hour. Maybe add another 30 for cleaning up all the wiring in the engine bay. 9 -12 hours seems excessive but I would recommend doing it yourself if possible.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
That’s about 4-5 hours of work
1979
Baltimore, MD
Why not get a second quote from another shop? Compare them and see if it’s reasonable.
A lot of shops don’t bill at a rate of clock hour = billed hours. The “hour” is just a unit of measurement. Some techs work faster than others so it’s not fair for a fast tech to make less money than a slow tech for the same install.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Depending on the kit...
We charge $200 for a roof light bar ($300 for a Baja Designs Linkable or Diode Dynamics CrossLink Kit)
$100 for ditch lights
$200 for a triple fog kit
That's assuming the kits were purchased from us (we don't install customer provided items) as we know what harnesses are in there. And assuming it's all upfitter connections.
What did they charge you?
We charge $100/hour
We'd normally tackle all of that in about 3-4 hours with 2 guys working on it.
BroncoTrail
BroncoTrail
Salt Lake City
We charge $100/hour
They are charging $119/hr and estimating at 9-12 hours which I think is really, really high. I am going to look around some more today.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Yeah they are ripping you off
BroncoTrail
BroncoTrail
Salt Lake City
Man... I got another quote for less than half of the first one. This sounds way more reasonable. Thanks all for the support lol
Ford Bronco How long to install light bar, ditch lights, and fog lights? 1681442983005
