How to Turn On Ignition Without Starting Engine?
RideEmCowboy
Portola Valley, CA
'95 Mustang,'08 Honda Civic,'03 15hh QH Paint mare
Cannot figure this out from the 562 page manual: I want to program radio and a bunch of other settings while Bronco is parked. (just got im yesterday!) How do I turn on the systems w/o starting the engine? (Please understand I'm coming off a '95 Mustang where you turned the key to accessory position :) ) Thanks.
GToddC5
Todd
South Jersey
www.bronco6g.com
I think I discovered this by mistake the other day. Try hitting Start, but without pressing the brake pedal. I think that got me in ACC mode of some kind.
Edit: Found it:
Ford Bronco How to Turn On Ignition Without Starting Engine? 1645030679204
drew707
Ford Explorer
As others have said you just push the button without your foot on the brake pedal.
Also if you hit the power button on the radio knob it will turn that on. I think it runs for 15 or 30 minutes and then shuts off. You don’t need to be in ACC mode at all to do this
OtisFE
Otis
Palm Coast FL
2022 Bronco OBX
Also, if you're just adjusting settings, if you hit the start button twice it will turn of the unnecessary "preparing to start" stuff.
WuNgUn
Ontario Canada
2 door Squatched
Is this a fact? Nice to know you don't need your HVAC and dash on when in ACC mode
RideEmCowboy
RideEmCowboy
Portola Valley, CA
So I hit it twice without pressing the brake pedal?
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
I'm not sure the "hit it twice" has been verified, but pressing START just once WITHOUT your foot on the brake pedal definitely works.
RideEmCowboy
RideEmCowboy
Portola Valley, CA
Thanks, everyone! Of course that did the trick and I was able to change the settings, program the radio, etc.
The User Manual is often pretty useless. For one thing, there's no global diagram of where everything is. Each affordance is section by section. For instance, they show you a giant photo of the mirror adjustment controls w/o any indication of where they are in truck (center console). In my last car, they were to the L of the steering wheel. Had to go Google to locate the switches. I used to write user manuals, so I get peeved when they're not well done.
JohnnyMotorBoat
Austin, TX
Ford Bronco Wildtrak 2 Door
I'm well aware of starting in what Bronco calls "accessory mode" by pressing the start button without your foot on the brake. However in this mode the HVAC, headlights, and everything else if fully powered without the engine running, and I suspect you're draining your battery rapidly in this state. Every other car I've owned (including push button start ones) has these modes: LOCK (0), ACCESSORY (I), ON (II), and START (III). Typically "Accessory (I)" powers up radio and the touchscreen / system menus, but NOT headlights and HVAC - which is typically "On (II)" mode.
It appears when you press start without your foot on the brake the Bronco is in "On II". Do we not have an equivalent to "Accessory (I)" in the Bronco? I'd prefer to be able to mess with all my Sync Settings, read the onboard user manual, etc. without draining the battery. Is this possible?
Planet_Express_IV
2013 Ford Focus ST
Just hit the power button on the radio itself if you only want to turn on the radio, but you'll also need to turn it off the same way. It can be powered by itself with everything else in the dormant state. That's how it's worked in my Ford's with push button start since 2013.
RideEmCowboy
RideEmCowboy
Portola Valley, CA
Yep, turn off the audio & AC w/ their own buttons if you don't want them in XSRE mode.
Bronco23
As others have mentioned press the Start button once without Foot on the Brake will put it in the ON Mode, with headlights, A/C etc. Press it a Second time without Foot on brake and it will change it over to ACC mode saving the battery.
RideEmCowboy
RideEmCowboy
Portola Valley, CA
Yes, that works, too. Forgot to mention.
HCGxKaLiBeR
CT
2025 BMW X2 M35i
This tread reminded me back in the day I had the same but opposite issue.
I just turn the key to start the car. Just turn once to energize, twice to start the engine.
No foot needed on the brake.
When I first had the push button car, for the first 15 minutes I could not figure out how to start the engine until I tried putting my foot on the brake. I was like DOH! :ROFLMAO:
